Dual fuel slide in range instrument panel is cracked. The timer has a mind of its own. Goes on by itself without being set. I have to turn the electricity off to stop it. Self cleaning cycle doesn't work, maybe worked once since we got it. Are there any parts available for this model?
The bezel and the control board for this range are available. We need the color of the control panel in order to provide the correct part number.
