armandoroig
#1 Posted : Friday, April 24, 2009 8:32:45 AM(UTC)
armandoroig
When the oven turns on, it only goes on in High temperature, the fire is too intense. There is no way to control it down. It eventually turns off I guess by temperature. However it is impossible to cook like that. What part should I change?
Thanks in advance for your answer.
roland223
#2 Posted : Wednesday, August 5, 2009 7:18:21 AM(UTC)
roland223
oven turns on o.k. but it won't turn off. gas continues to flow even after the oven is shut off. I turn the gas off to to shut the oven off. If I turn the gas back on it flows at a slower rate. Even if the the oven is not lit.
( it's propane) mod no. CGW3B5WK Thanks Roland Hall
#3 Posted : Wednesday, August 5, 2009 11:57:57 AM(UTC)
Hi Roland,
If the igniter stays on even the thermostat is off then the problem is a bad oven thermostat.
The model number you posted does not come up. The closest model number I found is Model CGW3D5WK . Verify and repost it.
roland223
#4 Posted : Thursday, August 6, 2009 6:54:05 AM(UTC)
roland223
Hi Roland,
Gene, the igniter comes on and goes off with the control knob. the propane flows to the burner wheather the control knob is on or off.
thanks : roland223
#5 Posted : Thursday, August 6, 2009 2:26:37 PM(UTC)
Sounds like the problem is a bad gas safety valve. I'm not sure about the part number because you did not confirm the model number.
