I cant get the oven to work. Top elements work fine but the coven does not work the diplay shows the fan turning. But fan in oven stays off with no heat in convection mode or regular mode. If anyone can help would be much apprieciated. Tnx
THIS FORUM IS DEAD!!!!!!! |
Originally Posted by: denman Thanks for your help Got one error code to come up it was 00 64 No letters and cannot find this code any where also a number comes up on the bottom of the display AM70 UI73 EEKEO-068 I have checked continuity on the limits that I can see. I read somewhere that they have trouble with the oven thermostat whenever there is a self cleaning done. Any help would be much appreciated thanks
