Discuss
Instructions on replacing potentiometer switch
 in
One of the burners on my Thermador cook top is sparking when turned on but gas does not flow. I
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Instructions on replacing potentiometer switch
  #1 (permalink)
Old 12-04-2007, 04:29 PM
gbumaga gbumaga is offline
Junior Member
gbumaga is on a distinguished road
Default Instructions on replacing potentiometer switch
Model Number: sgcs365rs   Brand: Thermador   Age: 5 - 10 years
One of the burners on my Thermador cook top is sparking when turned on but gas does not flow. I understand, after finding some information on the web, that most likely I need to replace the potentiometer switch. Does anyone has instructions on how to get to it? I suspect that first I need to remove the cover, but not sure how to do it. Please help!
Many thanks in advance,
George
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 12-05-2007, 01:46 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Which burner is not working properly? Only two of them have the potentiometers.
Also I need you to post the serial number of the unit.
- Here are the break down diagrams for the Thermador range Model SGCS365RS
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 12-05-2007, 09:04 PM
Junior Member
Default
Hi Gene.
Thank you very much for your answer. The serial number is 99050965. The burner which does not work is the front right one (#14 on the diagram).
Thanks,
George.
  #4 (permalink)
Old 12-06-2007, 12:19 AM
Gene's Avatar
Senior Expert
APP Volunteer
Default
The problem could cause by one of two parts: the gas burner valve or the knob cracked inside.
The gas burner valve is no longer available.
- The part number for the knob AP2832336
__________________
  #5 (permalink)
Old 12-06-2007, 12:50 PM
Junior Member
Default
Thanks Gene! I will try to the knob from other burner to see if this is the problem. I hope that it's so easy... In case it's not, what are my options if new gas burner valve is not available? Does it mean that I need to forget about this burner and just live with it?
Thanks again,
George
  #6 (permalink)
Old 12-06-2007, 12:57 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Not much options.
Hopefully you can survive.
__________________
  #7 (permalink)
Old 12-06-2007, 01:46 PM
Junior Member
Default
In case I can find a used valve, how do I get to it - from the top or bottom? Is there easy way to take off the cover?
Thanks!
  #8 (permalink)
Old 12-06-2007, 01:49 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Access to all parts is from the top. You can see it on the break down diagrams in one of my previous posts.
__________________
  #9 (permalink)
Old 12-06-2007, 02:36 PM
Junior Member
Default
I must be asking very elementary and stupid questions since I have no experience at all with the stoves - what is holding the top down? Do I need to unscrew something or some clips holding it. I can not figure out from the diagram how to get it off.
Thanks...
  #10 (permalink)
Old 12-06-2007, 02:46 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
In the middle of each burner is a part called a "venture" (#12 on the main top break down diagram). You have to remove all of them, remove burners and then the top panel.
To remove ventures could be a big problem due to rust. You can not force it very much to prevent damage to gas tubes under the top panel.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Help - instructions to install oven igniter lrg51 Oven Repair (including Ranges and Cooktops) 27 07-07-2008 02:14 PM
infinite switch wiring change from 6 wires to 5 wire switch wiedemanndds Oven Repair (including Ranges and Cooktops) 3 12-06-2007 01:45 PM
Replacing the griddle infinite switch J Black Oven Repair (including Ranges and Cooktops) 1 11-19-2007 02:46 PM
Instructions for changing coils Leesa Dryer Repair 2 10-25-2007 08:16 AM
Need Wiring instructions PLEASE!!! Scott e Dryer Repair 2 10-24-2007 02:06 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
