Discuss
DACOR ERROR L60 - Lower Fan Bad??
 in
Does anyone have any info on this error code and how to fix it? I have a 14 month old
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » DACOR ERROR L60 - Lower Fan Bad??
  #1 (permalink)
Old 12-04-2007, 11:22 AM
jonmcw jonmcw is offline
Junior Member
jonmcw is on a distinguished road
Unhappy DACOR ERROR L60 - Lower Fan Bad??
Model Number: MOV230s   Brand: Dacor   Age: 1 - 5 years
Does anyone have any info on this error code and how to fix it? I have a 14 month old Dacor Double oven wall mount- "Top 'o the line" so they told me --$5700 worth... Anyway, I NEVER use the bottom oven. Maybe once in the entire 14 months that I've owned this beast. This Thanksgiving dinner was at my place and I when I tried to fire the bottom oven up, it won't work! L60 is what the display says. I found ONE reference to this code online - Lower Cooling Fan failure. HuH! I won't even ask how that could be with only one use in the past year, but how convenient that the unit is now 2 months out of warranty and I've got Christmas Dinner to prepare for 20 people.
HELP!!
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 12-04-2007, 04:24 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Yes, the error code L60 means a lower oven cooling fan failure.
The complete description of the problem and solutions you can find in the service manual (page 12).
Most likely the problem is just blocked air flow and you would not have to replace any parts, but just in case:
- The part number for the cooling fan AP4087095
To find out the right part number for the relay board I need the serial number of the oven.
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 12-11-2007, 10:30 AM
Junior Member
Default Reset error code - Harm to oven?
Thanks for your rapid response. I have another question or two..
In speaking with the Dacor folks they gave me the reset code so that I can continue to use the top oven (Control+Secure+#, S1234). It worked!
Now when I activate the bottom oven it heats, but the fan does not spin AND the display tells me to "close the door" even tho it is shut.
Q1) Will I harm the oven if I continue to use the upper unit?
Q2) How do I diagnose a bad relay board? (cant find the serial number on the oven, but the sticker on the front of the manual says MOV230S*V-C-06090415)
Q3) How can I access the full Service Manual so I can utilize the "Service Screens" as described in the Service manual?
I'm pretty handy with electrical so I'm sure I can handle the replace/repair as long as I have your forum to hold my hand.
  #4 (permalink)
Old 12-11-2007, 11:58 AM
Gene's Avatar
Senior Expert
APP Volunteer
Default
(1) I do not think if you continue to use the upper oven will cause any damages to the lower one.
(2) The name plate with the model and the serial numbers is behind the upper door latch access panel. You can read it through the vents.
The diagnostic procedure described in the service manual, posted previously.
(3) You can find the information about "Service Screens" in the second part of the service manual, but you have to have a Service ID # in order to use it with your oven.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dacor Oven won't heat devorahbee Oven Repair (including Ranges and Cooktops) 1 05-24-2008 10:56 PM
dacor raised vent evergreenc Oven Repair (including Ranges and Cooktops) 10 05-04-2008 09:26 AM
Dacor raised vent keypad removal sabraham Oven Repair (including Ranges and Cooktops) 0 11-20-2007 11:23 PM
Dacor Oven / Pure convection mode GOP Oven Repair (including Ranges and Cooktops) 3 11-20-2007 06:25 PM
Dacor lower oven not heating innovatech Oven Repair (including Ranges and Cooktops) 0 10-25-2007 10:44 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
