Discuss
No Bake after element replacement
 in
The bake element went out for the first time last week so I replaced it. The stove top and broil
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » No Bake after element replacement
  #1 (permalink)
Old 12-04-2007, 11:05 AM
Chickenman Chickenman is offline
Junior Member
Chickenman is on a distinguished road
Default No Bake after element replacement
Model Number: RF388LXG0   Brand: Whirlpool   Age: 5 - 10 years
The bake element went out for the first time last week so I replaced it. The stove top and broil work but the bake element doesn't heat up. It has not given any error codes. It appears that both of the open frame relays on the display board are working properly. Is there another part that would keep the bake element from working even though the broil element works?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 12-04-2007, 12:41 PM
TechnicianBrian's Avatar
TechnicianBrian TechnicianBrian is offline
Senior Expert
APP Volunteer
TechnicianBrian is on a distinguished road
Default
I would suspect one of the terminal connectors to the element came loose during installation. If you have a meter, take the back off and turn on the bake element and check your voltage at both terminals. You should have approx 240 volts AC. If you are only getting 120 volts AC, then you have a voltage source problem, if you have the 240 volts AC but no heat, you have an element problem.
TechnicianBrian
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
replacing bake element staceymoore01 Oven Repair (including Ranges and Cooktops) 2 06-13-2008 11:25 PM
Matag Bake Element troubleshooting jccouch1 Oven Repair (including Ranges and Cooktops) 1 11-12-2007 06:24 PM
Bake element problem? sdhwah Oven Repair (including Ranges and Cooktops) 1 11-12-2007 10:36 AM
Bake Element Installation HelpMeHelpMe Oven Repair (including Ranges and Cooktops) 2 08-20-2007 04:00 PM
Bake Element and BAKE cycle not working jeffman Oven Repair (including Ranges and Cooktops) 1 08-04-2007 11:18 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
