Upper oven lower heating element does not work. Original element burned out (melted through). Replaced twice with same results. Lower element does not heat up on bake. Light comes on and upper element heats up like normal. Thermostat shuts off at correct temperature. Seems that everything works like normal except that lower element.
Please suggest the next step to repair. This unit was built in 1981. Cannot find any fuses or breakers in the circuitry.
Thanks!
To clarify, the subsequent replacement elements did not burn through, they just do not heat at all.
