Hello! Our gas oven was not heating, bake or broil was not working. We replace the ignitor and the broil started working but the bake is still not working. We were told the fuses may be out. We tested both with a multimeter. The fuse w/ the prongs up had continuity. The fuse with the flat prongs did not have continuity so we ordered a replacement part from Appliance Parts Pros (order #2094479, part # 9759944 THRMST-FIX). We installed the new part and the oven still was not working. We tested the new part and there was no continuity. We were sent another replacement part and we are having the same issue: oven not working, part has no continuity.
Is it possible that this fuse type, w/ the flat prongs, will never test w/ continuity? If so, what else could be the issue w/ our oven?
