Discuss
Tappan Oven Microwave Combo
 in
I have a Tappan Oven Microwave Combo with overhead pull out exhaust fan from the mid 1980's. The oven
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Tappan Oven Microwave Combo
  #1 (permalink)
Old 04-21-2009, 01:40 PM
mjwhite mjwhite is offline
Junior Member
mjwhite is on a distinguished road
Default Tappan Oven Microwave Combo
Model Number: 76-4232-23/06355-8351   Brand: Tappan   Age: Less than 1 year
I have a Tappan Oven Microwave Combo with overhead pull out exhaust fan from the mid 1980's. The oven and stove top work great but the microwave and overhead pullout exhaust fan has no power. I am assuming this is perhaps a fuse issue but do not have a manual to locate it. I also am assuming that either the exhaust fan motor could have blown the fuse or perhaps the microwave unit itself has a short. By replacing the fuse and powering up each one of them separatly, I should know where the problem is. Anyone have a wiring diagram for this unit? Or has anyone experienced a similiar problem?
Thanks,
Marc
Related Models
Frigidaire 76-4232-45-14 Tap(v3) / Gas Range
Frigidaire 76-4232-57-14 Tap(v4) / Gas Range
Frigidaire 76-4232-66-14 Tap(v5) / Gas Range
Frigidaire 76-4667-00-01 Tap(v1) / Gas Range
Frigidaire 76-4667-00-02 Tap(v5) / Gas Range
Frigidaire 76-4667-00-03 Tap(v1) / Gas Range
Frigidaire 76-4667-00-04 Tap(v5) / Gas Range
Frigidaire 76-4667-00-05 Tap(v1) / Gas Range
Frigidaire 76-4667-00-06 Tap(v5) / Gas Range
Frigidaire 76-4667-00-07 Tap(v9) / Gas Range
Frigidaire 76-4667-00-08 Tap(v1) / Gas Range
Frigidaire 76-4667-08-01 Tap(v4) / Gas Range
Frigidaire 76-4667-08-02 Tap(v8) / Gas Range
Frigidaire 76-4667-23-01 Tap(v2) / Gas Range
Frigidaire 76-4667-23-02 Tap(v6) / Gas Range
Frigidaire 76-4667-23-03 Tap(v2) / Gas Range
Frigidaire 76-4667-23-04 Tap(v6) / Gas Range
Frigidaire 76-4667-23-05 Tap(v2) / Gas Range
Frigidaire 76-4667-23-06 Tap(v6) / Gas Range
Frigidaire 76-4667-23-07 Tap(v10) / Gas Range
Frigidaire 76-4667-23-08 Tap(v2) / Gas Range
Frigidaire 76-4667-32-03 Tap(v4) / Gas Range
Frigidaire 76-4667-32-04 Tap(v8) / Gas Range
Frigidaire 76-4667-32-05 Tap(v4) / Gas Range
Frigidaire 76-4667-32-06 Tap(v8) / Gas Range
Frigidaire 76-4667-32-07 Tap(v12) / Gas Range
Frigidaire 76-4667-32-08 Tap(v4) / Gas Range
Frigidaire 76-4667-66-01 Tap(v3) / Gas Range
Frigidaire 76-4667-66-02 Tap(v7) / Gas Range
Frigidaire 76-4667-66-03 Tap(v3) / Gas Range
Frigidaire 76-4667-66-04 Tap(v7) / Gas Range
Frigidaire 76-4667-66-05 Tap(v3) / Gas Range
Frigidaire 76-4667-66-06 Tap(v7) / Gas Range
Frigidaire 76-4667-66-07 Tap(v11) / Gas Range
Frigidaire 76-4667-66-08 Tap(v3) / Gas Range
Frigidaire 76-4960-00-01 Tap(v1) / Gas Range
Frigidaire 76-4960-00-03 Tap(v1) / Gas Range
Frigidaire 76-4960-00-04 Tap(v3) / Gas Range
Frigidaire 76-4960-00-07 Tap(v1) / Gas Range
Frigidaire 76-4960-00-08 Tap(v3) / Gas Range
Frigidaire 76-4960-23-01 Tap(v2) / Gas Range
Frigidaire 76-4960-23-03 Tap(v2) / Gas Range
Frigidaire 76-4960-23-04 Tap(v4) / Gas Range
Frigidaire 76-4960-23-07 Tap(v2) / Gas Range
Frigidaire 76-4960-23-08 Tap(v4) / Gas Range
Frigidaire 76-4967-00-01 Tap(v1) / Gas Range
Frigidaire 76-4967-00-02 Tap(v5) / Gas Range
Frigidaire 76-4967-00-03 Tap(v9) / Gas Range
Frigidaire 76-4967-00-04 Tap(v1) / Gas Range
Frigidaire 76-4967-00-05 Tap(v5) / Gas Range
Frigidaire 76-4967-00-06 Tap(v9) / Gas Range
Frigidaire 76-4967-00-07 Tap(v1) / Gas Range
Frigidaire 76-4967-00-08 Tap(v9) / Gas Range
Frigidaire 76-4967-00-09 Tap(v1) / Gas Range
Frigidaire 76-4967-00-10 Tap(v9) / Gas Range
Frigidaire 76-4967-00-11 Tap(v1) / Gas Range
Frigidaire 76-4967-00-12 Tap(v1) / Gas Range
Frigidaire 76-4967-00-13 Tap(v1) / Gas Range
Frigidaire 76-4967-18-04 Tap(v4) / Gas Range
Frigidaire 76-4967-18-05 Tap(v8) / Gas Range
Frigidaire 76-4967-18-06 Tap(v12) / Gas Range
Frigidaire 76-4967-23-01 Tap(v2) / Gas Range
Frigidaire 76-4967-23-02 Tap(v6) / Gas Range
Frigidaire 76-4967-23-03 Tap(v10) / Gas Range
Frigidaire 76-4967-23-04 Tap(v2) / Gas Range
Frigidaire 76-4967-23-05 Tap(v6) / Gas Range
Frigidaire 76-4967-23-06 Tap(v10) / Gas Range
Frigidaire 76-4967-23-07 Tap(v2) / Gas Range
Frigidaire 76-4967-23-08 Tap(v10) / Gas Range
Frigidaire 76-4967-23-09 Tap(v2) / Gas Range
Frigidaire 76-4967-23-10 Tap(v10) / Gas Range
Frigidaire 76-4967-23-11 Tap(v2) / Gas Range
Frigidaire 76-4967-23-12 Tap(v2) / Gas Range
Frigidaire 76-4967-23-13 Tap(v2) / Gas Range
Frigidaire 76-4967-32-01 Tap(v4) / Gas Range
Frigidaire 76-4967-32-02 Tap(v8) / Gas Range
Frigidaire 76-4967-32-03 Tap(v12) / Gas Range
Frigidaire 76-4967-32-07 Tap(v4) / Gas Range
Frigidaire 76-4967-32-08 Tap(v12) / Gas Range
Frigidaire 76-4967-32-09 Tap(v4) / Gas Range
Frigidaire 76-4967-32-10 Tap(v12) / Gas Range
Frigidaire 76-4967-32-11 Tap(v4) / Gas Range
Frigidaire 76-4967-32-12 Tap(v4) / Gas Range
Frigidaire 76-4967-32-13 Tap(v4) / Gas Range
Frigidaire 76-4967-66-01 Tap(v3) / Gas Range
Frigidaire 76-4967-66-02 Tap(v7) / Gas Range
Frigidaire 76-4967-66-03 Tap(v11) / Gas Range
Frigidaire 76-4967-66-04 Tap(v3) / Gas Range
Frigidaire 76-4967-66-05 Tap(v7) / Gas Range
Frigidaire 76-4967-66-06 Tap(v11) / Gas Range
Frigidaire 76-4967-66-07 Tap(v3) / Gas Range
Frigidaire 76-4967-66-08 Tap(v11) / Gas Range
Frigidaire 76-4967-66-09 Tap(v3) / Gas Range
Frigidaire 76-4967-66-10 Tap(v11) / Gas Range
Frigidaire 76-4967-66-11 Tap(v3) / Gas Range
Frigidaire 76-4967-66-12 Tap(v3) / Gas Range
Frigidaire 76-4967-66-13 Tap(v3) / Gas Range
Frigidaire 76-8667-00-01 Tap(v9) / Gas Range
Frigidaire 76-8667-00-02 Tap(v13) / Gas Range
Frigidaire 76-8667-00-03 Tap(v9) / Gas Range
Frigidaire 76-8667-00-04 Tap(v13) / Gas Range
Frigidaire 76-8667-00-05 Tap(v13) / Gas Range
Frigidaire 76-8667-00-06 Tap(v17) / Gas Range
Frigidaire 76-8667-00-07 Tap(v5) / Gas Range
Frigidaire 76-8667-00-08 Tap(v9) / Gas Range
Frigidaire 76-8667-08-01 Tap(v12) / Gas Range
Frigidaire 76-8667-08-02 Tap(v16) / Gas Range
Frigidaire 76-8667-23-01 Tap(v10) / Gas Range
Frigidaire 76-8667-23-02 Tap(v14) / Gas Range
Frigidaire 76-8667-23-03 Tap(v10) / Gas Range
Frigidaire 76-8667-23-04 Tap(v14) / Gas Range
Frigidaire 76-8667-23-05 Tap(v14) / Gas Range
Frigidaire 76-8667-23-06 Tap(v18) / Gas Range
Frigidaire 76-8667-23-07 Tap(v6) / Gas Range
Frigidaire 76-8667-23-08 Tap(v10) / Gas Range
Frigidaire 76-8667-32-03 Tap(v12) / Gas Range
Frigidaire 76-8667-32-04 Tap(v16) / Gas Range
Frigidaire 76-8667-32-05 Tap(v16) / Gas Range
Frigidaire 76-8667-32-06 Tap(v20) / Gas Range
Frigidaire 76-8667-32-07 Tap(v8) / Gas Range
  #2 (permalink)
Old 04-22-2009, 01:40 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Default
Hi Marc,
The microwave and the exhaust fan are not connected and there is no fuse for the exhaust fan.
The fuse for the microwave (#3 on the diagram) is located behind the control panel. You have to remove the two screws on top and on the bottom of the control panel in order to open it (from the right side to the left). You have to remove the screws holding the cardboard cover on the left side to access the fuse. If the problem is just a bad fuse then you can order the new one, but if there something else wrong then there is a time for a new microwave. All major parts for this microwave are no longer available.
- The part number for the fuse is AP2137203
Here are the breakdown diagrams and Replacement parts for FRIGIDAIRE 76-4232-23-14 | AppliancePartsPros.com.
__________________
  #3 (permalink)
Old 04-22-2009, 01:49 PM
Junior Member
Default
Thanks Gene for your help and clarification on the fuse. It just seems strange that the pull out overhead fan and microwave went out at the same time. I will also check the main incoming wiring for a bad connection or something else. I'll keep you posted, thanks for the diagram too.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
microwave/oven combo bartsp Microwave Repair 0 02-25-2009 05:41 PM
wall mount microwave & oven combo 30 in hungtrinh Oven Repair (including Ranges and Cooktops) 2 02-16-2009 02:58 PM
Microwave / Oven Combo rprprp Microwave Repair 20 09-10-2008 06:12 AM
Whirlpool Microwave-Oven Combo MDVince Microwave Repair 4 01-27-2008 03:17 PM
Removing Microwave from Oven Combo diyall Microwave Repair 0 12-09-2007 08:22 AM
