| » kenmore oven doesn't work |
Model Number: 790.7869 Brand: Kenmore Age: 1 - 5 years
House power was interrupted during cleaning cycle. I reset the clock and started the cleaning cycle again. Although the indicator lights came on, the oven didn't heat during the cleaning cycle and the oven will not light at all. The top burner still lights and functions as a broiler. Also, this stove has a warming drawer that does work!
Ads By Google Related Models Last edited by jimneaf : 04-21-2009 at 12:00 PM. Reason: add information |
I was about to post a similar issue with a Kenmore Gas oven. I might be able to help you get the oven to work although, you'll have to baby sit it while it's on.
First thing you need to do is take the screws out that secure the bottom pan which will allow you access to the flame bar. Next. Turn on the oven to a desired temp and wait about 5 minutes. The igniter should be glowing. Now. In your right hand you'll need something about 2 feet long and somewhat on the heavy side. Open the door, lift up the pan and give the flame bar a firm tap with the object. It might take a couple of tries but the bar might just light up as it does in mine. I'm still not sure why this has happened to mine or why the aforementioned procedure works but, it does. I do have to baby sit the oven because it won't always re-light after the temp drops. That's when I take a whack at the door with a firm knee hit and it will re-light. |
Quote:
Quote:
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
Quote:
__________________
Remove the oven floor and the flame spreader. Check for 120VAC to the Bake igniter while the control calls for Bake. If there is proper voltage then replace the igniter.
- The part number for the Bake igniter is AP3963540 Gene.
__________________
Quote:
Help me understand how to determine if the igniter is the problem. I'm fairly handy but have a problem determining if the igniter is bad since it does glow. I took the door off and removed the floor pan to inspect the igniter operation one day and, it seemed to be working as it should. But while doing the inspection I somehow tapped on the flame bar and it immediately lighted. Also. When the flame bar lights after a good tap, it will only be a small flame until I tap it again which causes it to light up fully. I have a multi-tester. Thank you. |
| Display Modes | |
| Kenmore Triple Task oven elements do not work | thanksforhelp | Oven Repair (including Ranges and Cooktops) | 2 | 09-02-2009 11:36 AM |
| Kenmore Elec oven- both broiler and oven do not work | Ed Brodsky | Oven Repair (including Ranges and Cooktops) | 1 | 06-17-2009 09:52 AM |
| Kenmore oven won't work; displays a LOCK code | crystalbean | Oven Repair (including Ranges and Cooktops) | 3 | 02-23-2009 12:46 PM |
| Kenmore range oven don't work | R80True | Oven Repair (including Ranges and Cooktops) | 8 | 01-16-2009 12:36 PM |
| Kenmore Oven will not work | BB69 | Oven Repair (including Ranges and Cooktops) | 0 | 10-28-2007 09:13 PM |
