Discuss
kenmore oven doesn't work
 in
Locate the Bake gas safety valve. Remove the two wires from the gas valve terminals and check for continuity between
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » kenmore oven doesn't work
  #11 (permalink)
Old 04-23-2009, 05:01 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Locate the Bake gas safety valve. Remove the two wires from the gas valve terminals and check for continuity between them. If the circuit is open then the gas valve has to be replaced.
Post the results.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #12 (permalink)
Old 04-23-2009, 05:06 PM
Junior Member
jimneaf is on a distinguished road
Default
Thanks, I'll give it a try. Jim
  #13 (permalink)
Old 12-28-2012, 07:51 PM
Junior Member
jordan2000 is on a distinguished road
Default Kenmore oven doesn't work
I have the exactly problem and same model oven. The rang works well. I have replaced the igniter with a new one. The igniter just doesn't glowing. Then I checked the continuity of the igniter and the continuity of the gas valve. They are all good. What could be wrong? Thanks.
  #14 (permalink)
Old 12-28-2012, 08:02 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Quote:
Originally Posted by jordan2000 View Post
...I have the ... same model oven...
You are third or fourth person on this thread. Model numbers were different.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore Triple Task oven elements do not work thanksforhelp Oven Repair (including Ranges and Cooktops) 2 09-02-2009 12:36 PM
Kenmore Elec oven- both broiler and oven do not work Ed Brodsky Oven Repair (including Ranges and Cooktops) 1 06-17-2009 10:52 AM
Kenmore oven won't work; displays a LOCK code crystalbean Oven Repair (including Ranges and Cooktops) 3 02-23-2009 01:46 PM
Kenmore range oven don't work R80True Oven Repair (including Ranges and Cooktops) 8 01-16-2009 01:36 PM
Kenmore Oven will not work BB69 Oven Repair (including Ranges and Cooktops) 0 10-28-2007 10:13 PM
