Discuss
GE Profile Burner Ignition Inconsistant
 in
All four burner controls ignite the rear right burner. I'm guessing I need a new Spark module but I'
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » GE Profile Burner Ignition Inconsistant
  #1 (permalink)
Old 12-03-2007, 03:59 PM
nycphog nycphog is offline
Junior Member
nycphog is on a distinguished road
Default GE Profile Burner Ignition Inconsistant
Model Number: JGS968SH1SS   Brand: GE   Age: 1 - 5 years
All four burner controls ignite the rear right burner. I'm guessing I need a new Spark module but I'm not sure. This problem occurred when I replaced the glass top.
Part Number: AP3778816 made by GE
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 12-03-2007, 07:19 PM
ripleys ripleys is offline
Senior Expert
APP Volunteer
ripleys is on a distinguished road
Default
All four burners should spark at the same time no matter which burner you turn on....that's just the way the newer gas ranges work. Replacing the spark module won't cure that.
  #3 (permalink)
Old 12-04-2007, 08:25 AM
Junior Member
Default
Your reply doesn't help considering that before I replaced the glass top each dial would only ignite its respective burner. In other words it worked the same way it came.
I'm hoping someone has come across this problem before and knows what is wrong.
  #4 (permalink)
Old 12-04-2007, 07:20 PM
Senior Expert
APP Volunteer
Default
Well if you say that was the way it was working before you replaced the glass top, common sense says you did something wrong so your going to have to check over your work and make sure you haven't pinched any wires somewhere and none are touching ground (cabinet) anywhere. Sorry if I am no help...only been a GE service tech for 18 years.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Ge Profile Arctica nguyenbn Refrigerator & Freezer Repair 14 08-14-2008 09:47 AM
GE profile blew up bettye Microwave Repair 2 10-12-2007 06:05 PM
GE XL44 stove top ignition problem RonE Oven Repair (including Ranges and Cooktops) 1 09-10-2007 10:20 AM
GE Profile Cas range PJCIII Oven Repair (including Ranges and Cooktops) 3 08-27-2007 10:19 AM
Old Caloric Oven: irregular ignition and won't hold a temperature mhrichardson99 Oven Repair (including Ranges and Cooktops) 0 08-23-2007 10:20 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
