Oven comes up to set temperature OK (Example 400 F) . Main burner cuts out, but does not relight until temp has fallen 80 deg F.
How can I make the gas relight closer to 380 F?
Mike
Let me ask the question another way ...
When the oven temperature sensor fails, what are the typical symptoms seen in the operation of the oven? What resistance (ohms) should I expect to see across the sensor terminals at room temperature?
Thanks.
Mike
