Discuss
Cooktop stove main top will not come off
 in
I need to remove the main top to my Whirlpool stove/range/gas. It has electrical iginition and 4 burners
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Cooktop stove main top will not come off
  #1 (permalink)
Old 12-03-2007, 11:08 AM
vornato vornato is offline
Junior Member
vornato is on a distinguished road
Default Cooktop stove main top will not come off
Model Number: SF360BEEW   Brand: Whirlpool   Age: More than 10 years
I need to remove the main top to my Whirlpool stove/range/gas. It has electrical iginition and 4 burners on top. I can access the front of the stove top and lift it, but I can't find the rear hinges to lift it up off of the burners. The rear of the top has an upward curve to it with a gas vent in the middle. And it is hard to see where to lift it. Do I have to remove the back plate to access the hinges for removal and do I need to remove the burner plates to remove the top. If I could loosen the back hinges that is get access to them I could lift the top without removing the burners themselves, which are attached to the main top with screws. Any info helpfull.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
installing the Assy, main bearing jdouglas14 Washer Repair 4 12-03-2007 06:33 PM
Installing the main belt cutco760 Dryer Repair 1 11-01-2007 04:57 AM
Ceramic Cooktop slide-in oven/stove EVdelRsoario Oven Repair (including Ranges and Cooktops) 1 09-19-2007 01:48 PM
Double Oven--Main oven not working bccavanaugh Oven Repair (including Ranges and Cooktops) 1 09-15-2007 11:22 PM
Main pump motor is not activated. gebman1 Dishwasher Repair 0 07-31-2007 11:05 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
