| » oven won't heat up |
| By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use. |
Model Number: cre9400acw Brand: Maytag Age: More than 10 years
I set temp to 400 and oven preheats in less than a minute - after 20mins oven temp only 200 deg - is this a control panel problem?
You could check the thermostat sensor in the oven itself. It sends a message to the controls. I am not up on how to test this. But if you look for some info on posts someone may know. I believe it is either good or bad, meaning if you check it with an ohmeter, it either reads 0 or infinite or a low scale reading. Again I am not sure on the exact procedure. But it should be checked.
| Display Modes | |
| Bosch 27" Dbl oven Powering on but no heat either oven | badace | Oven Repair (including Ranges and Cooktops) | 0 | 12-02-2007 09:56 AM |
| oven doesn't heat up | Saskia | Oven Repair (including Ranges and Cooktops) | 4 | 11-26-2007 10:17 PM |
| Oven will not heat | lznuk | Oven Repair (including Ranges and Cooktops) | 1 | 11-16-2007 05:09 PM |
| Oven doesn't heat up | mistyw | Oven Repair (including Ranges and Cooktops) | 0 | 09-07-2007 09:47 PM |
| Oven won't heat up at all. | acillatem | Oven Repair (including Ranges and Cooktops) | 27 | 07-26-2007 11:32 PM |
