I have had the same problem as others. The oven ignitor comes on, clicks, ignites, but keeps on clicking then all goes off. I tried the hole enlarging, it worked for a while, then went back to cutting off. I ordered the new burner / ignitor from your site. After installing it worked fine. When we went to actually use the oven, the same thing happened, the ignitor clicked, burner came on, ignitor continued to click, and it all shut down............What do I do next??????
