| » Wiring question for Jenn Air oven |
Model Number: W130-C Brand: Jenn-Air Age: 1 - 5 years
I have a customer that had there cabinets resurfaced and the cabinet guys pulled out the wall oven and disconnected the main power line that goes into the oven. The problem I ran into re installing it (because I was not the one to take it out) was there are 5 wires in the main power cord to the oven. Red, Black, White, ground and some blue wire. The blue wire has a spade terminal on the one end that goes into the oven, and the other end was joind in the box somewhere. I joined all the other wires accordingly and the oven works fine, but I have no digital display or oven light. There is no wiring diagram to be found anywhere on the oven so I am kind of lost as to how and where that blue wire comes into play. Any info or any place I might find a wiring diagram on line would be greatly appreciated.
Thanks in advance. John |
__________________
Professional appliance repair in Los Angeles, California. |
Thanks for the quick reply Gene, but the wiring diagram you gave me only shows a 4 wire supply and no blue wire. I am dumb founded as to where and why this wire is used, but it must be needed for something as before it was disconnected by the cabinet guys, there was a digital display and the oven light worked, now no light in oven and no digital display, yet the oven works and cycles fine. I think I am going to have words with the cabinet installers and hopefully they will remeber where they pulled the wire off. Thanks again.
This is the only wiring diagram available for this model number.
__________________
| Display Modes | |
| Jenn-Air Wall Oven display | tyke58 | Oven Repair (including Ranges and Cooktops) | 3 | 08-27-2008 07:35 PM |
| Jenn Air gas oven won't heat | kkenaga | Oven Repair (including Ranges and Cooktops) | 1 | 11-20-2007 01:45 PM |
| Question about replacing an oven control panel | Arnheimacres | Oven Repair (including Ranges and Cooktops) | 0 | 10-02-2007 07:09 PM |
| Jenn-Air Wiring | ezra710 | Oven Repair (including Ranges and Cooktops) | 0 | 09-20-2007 09:39 AM |
| Jenn-Air Wiring Repair Rescue | JenSed | Oven Repair (including Ranges and Cooktops) | 5 | 08-21-2007 11:53 AM |
