Discuss
Blower Motor shuts down during use
 in
I own a Jenn Air Electric Grill, about 25 years old and subject to average use. The blower has recently
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Blower Motor shuts down during use
  #1 (permalink)
Old 04-18-2009, 03:37 PM
Junior Member
rquack is on a distinguished road
Default Blower Motor shuts down during use
Model Number: C101   Brand: Jenn-Air   Age: More than 10 years
I own a Jenn Air Electric Grill, about 25 years old and subject to average use. The blower has recently begun to shut down during use. If only the blower is turned on it will run for 45 minutes without any problem, however, the end of the motor near the shaft will become quite warm. But when the electric heating elements are energized, the fan will shut down after about 15-20 minutes. When the heating elements are shut down, the blower will come back on after about 10-15 minutes. While the heating elements are energized the shaft area of the blower motor becomes extremely hot, but no noises are heard out of the ordinary, no grinding, no bearing noise. No difference in performance is noted by having the fan in manual or automatic mode.
Is there a thermal switch that may be reaching the end of its service life? Or am I looking at needing a new motor?
Also, the efficiency of the unit in gathering and moving "smokey" air from around the grill has been gradually degrading over time. Will cleaning the squirrel cage improve this area of performance? The vent system has been periodically cleaned to prevent any dust, accumulations, etc.
Ads By Google
Related Models
Jenn-Air C101 Surface Unit - Ddraft Ele
Jenn-Air C101-C Surface Unit - Ddraft Ele
Jenn-Air C101-J Surface Unit - Ddraft Ele
Amana C101DW Freezer - Chest
Amana C101FW Freezer - Chest
Jenn-Air C102 Surface Unit - Ddraft Ele
Amana C102B Room Air Conditioner
Jenn-Air C106 Surface Unit - Ddraft Ele
Jenn-Air C106-C Surface Unit - Ddraft Ele
Hoover C1065--- Uprt - Hd,lc,mid,gns,ns,gmn,pr As,com,id
Hoover C1067--- Uprt - Hd,lc,mid,gns,ns,gmn,pr As,com,id
Hoover C1069--- Uprt - Hd,lc,mid,gns,ns,gmn,pr As,com,id
Hoover C1085--- Uprt - Hd,lc,mid,gns,ns,gmn,pr As,com,id
Hoover C1091--- Uprt - Hd,lc,mid,gns,ns,gmn,pr As,com,id
Hoover C1099--- Uprt - Hd,lc,mid,gns,ns,gmn,pr As,com,id
Maytag C10AALWH Freezer - Chest
Amana C10B Freezer - Chest
Amana C10B-2 Freezer - Chest
Amana C10B-A Freezer - Chest
Amana C10B-AG Freezer - Chest
Amana C10B-C Freezer - Chest
Amana C10B-G Freezer - Chest
Amana C10B-L Freezer - Chest
Amana C10B1 Freezer - Chest
Amana C10B3W Freezer - Chest
Maytag C10D  Freezer - Chest
Maytag C10J  Freezer - Chest
Amana C11 Freezer - Chest
Hoover C1111--- Uprt - Hd,lc,mid,gns,ns,gmn,pr As,com,id
Hoover C1119--- Uprt - Hd,lc,mid,gns,ns,gmn,pr As,com,id
Hoover C1119080 Uprt - Hd,lc,mid,gns,ns,gmn,pr As,com,id
Hoover C1121--- Uprt - Hd,lc,mid,gns,ns,gmn,pr As,com,id
Hoover C1123--- Uprt - Hd,lc,mid,gns,ns,gmn,pr As,com,id
Hoover C1125--- Uprt - Hd,lc,mid,gns,ns,gmn,pr As,com,id
Jenn-Air C116 Surface Unit - Ddraft Ele
Jenn-Air C116-C Surface Unit - Ddraft Ele
Amana C11B Freezer - Chest
Amana C11B-A Freezer - Chest
Amana C11B-C Freezer - Chest
Amana C11B-G Freezer - Chest
Amana C11B-L Freezer - Chest
Amana C11F Freezer - Chest
Amana C11F-A Freezer - Chest
Amana C11F-AG Freezer - Chest
Amana C11F-C Freezer - Chest
Amana C11W Freezer - Chest
Amana C11W-A Freezer - Chest
Amana C11W-AG Freezer - Chest
Amana C11W-C Freezer - Chest
Amana C122B Room Air Conditioner
Maytag C12HE  Freezer - Chest
Maytag C12HS  Freezer - Chest
Maytag C12J Freezer - Chest
Thermador C12M
Hoover C1401--- Uprt - Hd,lc,mid,gns,ns,gmn,pr As,com,id
Hoover C1403--- Uprt - Hd,lc,mid,gns,ns,gmn,pr As,com,id
Hoover C1404--- Uprt - Hd,lc,mid,gns,ns,gmn,pr As,com,id
Hoover C1405--- Uprt - Hd,lc,mid,gns,ns,gmn,pr As,com,id
Hoover C1407--- Uprt - Hd,lc,mid,gns,ns,gmn,pr As,com,id
Hoover C1409910 Uprt - Hd,lc,mid,gns,ns,gmn,pr As,com,id
Hoover C1411930 Uprt - Hd,lc,mid,gns,ns,gmn,pr As,com,id
Hoover C1412-900
Hoover C1413930 Uprt - Hd,lc,mid,gns,ns,gmn,pr As,com,id
Hoover C1414900 Uprt - Hd,lc,mid,gns,ns,gmn,pr As,com,id
Hoover C1415--- Uprt - Hd,lc,mid,gns,ns,gmn,pr As,com,id
Hoover C1417903 Uprt - Hd,lc,mid,gns,ns,gmn,pr As,com,id
Hoover C1425--- Uprt - Hd,lc,mid,gns,ns,gmn,pr As,com,id
  #2 (permalink)
Old 04-19-2009, 05:05 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Replacement parts for JENN-AIR C101 | AppliancePartsPros.com
Does sound like the thermal protect/cutoff inside the motor is tripping.
Parts do show a filter but I would imagine you have already cleaned or replaced this.
Cleaning the fan blades may help. A coating of grease/dust on them will drastically reduce that air flow. Also clean the blower housing.and the cooling openings on the back of the motor. Give the motor shaft a spin to check that it is OK.
__________________
  #3 (permalink)
Old 04-20-2009, 12:08 PM
Junior Member
Default
I completely disassembled the unit and thoroughly cleaned the blower assembly; this improved air flow markedly. The foam strip requiring cooling air to be drawn through the motor was completely deteriorated; it was replaced. The motor was lubed and run prior to re-assembly; very quiet and no odd noises.
Upon reassembly I ran the motor for about 30 minutes without the heating elements engaged. The motor quit again about 30-35 minutes after the heating elements were turned on. After shutting the heating elements off, the blower resumed operation after about 8 minutes. When it was not operating I checked the power going to the motor at the junction box; it was uninterrupted. Is there a thermal cut off inside of the electric motor? Must the entire motor be replaced in order to repair this problem or is a component part available to accomplish a fix?
  #4 (permalink)
Old 04-20-2009, 07:00 PM
Senior Expert
APP Volunteer
Default
Yes
You have to replace the motor.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Blower Motor not working mooney99 Heating, Ventilation, and Air Conditioning (HVAC) 3 02-24-2010 03:48 PM
Blower Motor RWKEND Oven Repair (including Ranges and Cooktops) 0 02-18-2010 08:52 AM
Blower Motor neboshone Heating, Ventilation, and Air Conditioning (HVAC) 1 10-03-2009 05:52 AM
dryer blower motor lakesideguy Dryer Repair 1 04-08-2009 08:16 PM
why did my blower motor slow down tboss Heating, Ventilation, and Air Conditioning (HVAC) 9 03-03-2009 07:55 AM
