My upper oven light comes on when I use the control panel button or open the lower oven door but not when I open the upper oven door. I put in a new door switch but this didn't solve the problem. Also I get an F8 message when I try pressing the clean button for the upper oven. If the problem is a lock switch or lock motor would the light normally still be coming on when I open the upper door?
