Denman if you're out there, I checked the thermal switch as suggested it checked out. As you know I replaced the temp sensor. The control panel comes on when the power is on and everything acts as if it's working but nothing heats. The door will lock if set to clean, the oven acts as if it's preheating etc. Is there anything else I can try or is the control board shot? Thanks again for your help :confused:
THIS FORUM IS DEAD!!!!!!! |
