I have a Maytag mgr5870adw. The top burners work fine but the oven will not light. I tested the voltage on the ignitor, it climbed to 2.3vac and stoped. I replaced the ignitor 12400035 and the voltage still does not go above 2.3vac. The new ignitor does not get hot and has 210 ohms across the leads when disconnected. What do I do?
