Greetings, how do I disassemble the door to place in the new oven seal. it is the seal that is the larger one around the outer part of the door on the inside not the one that is a thin like rope that is in the glass insert. I have ordered the part and removed the handle, the outer glass, the tin shield, isultation and the oven glass window that is in the door. I could not figure out how to remove the rest. Do I need to pull out the hinges. Baffled. If anyone knows please advise. These things are usually easy when you know the proper steps. Thanks
