Discuss
REd E6 and Light-Blue F2 Appliance Fault Codes
 in
Friday morning, 17 April 2009 An appliance repairman replaced the touch pad (PART: WPL 8300531) earlier this week after Appliance
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » REd E6 and Light-Blue F2 Appliance Fault Codes
  #1 (permalink)
Old 04-16-2009, 09:26 PM
Junior Member
Col. L. R. Hughes, AF Ret is on a distinguished road
Default REd E6 and Light-Blue F2 Appliance Fault Codes
Model Number: RBD275PDT10   Brand: Whirlpool   Age: 5 - 10 years
An appliance repairman replaced the touch pad (PART: WPL 8300531) earlier this week after Appliance Fault Codes E6 and F2 appeared accompanied by beeping, then no lights at all, then the codes again, repeating. Oven light would come on when opening either the top or bottom of the double, self-cleaning oven. For a day the oven worked well, then the same codes, beeping, etc., began again. Turning off the power to allow it to reset did not help. What do I try next: could the connector to the keypad be loose? do I need to replace the transformer? and/or replace the control board?
I would be grateful for any suggestions I can pass onto the appliance repairman. Thank you.
Ads By Google
Related Models
Whirlpool RBD275PDT10
Whirlpool RBD275PDT11
Whirlpool RBD275PDT12
Whirlpool RBD275PDT13
Whirlpool RBD275PDT14 27" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD275PDT15 27" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD275PDT8
Whirlpool RBD275PDT9
Whirlpool RBD275PRB00 24" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD275PRQ00 24" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD275PRS00 24" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD275PRS01 27" Built - in Electric Double Oven Convection - Upper Self - Clean (gold Line)
Whirlpool RBD275PRT00 24" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD276PDB1
Whirlpool RBD276PDB10
Whirlpool RBD276PDB11
Whirlpool RBD276PDB12
Whirlpool RBD276PDB2
Whirlpool RBD276PDB4
Whirlpool RBD276PDB6
Whirlpool RBD276PDB7
Whirlpool RBD276PDB8
Whirlpool RBD276PDB9
Whirlpool RBD276PDQ1
Whirlpool RBD276PDQ10
Whirlpool RBD276PDQ11
Whirlpool RBD276PDQ12
Whirlpool RBD276PDQ2
Whirlpool RBD276PDQ4
Whirlpool RBD276PDQ6
Whirlpool RBD276PDQ7
Whirlpool RBD276PDQ8
Whirlpool RBD276PDQ9
Whirlpool RBD277PDB1
Whirlpool RBD277PDB2
Whirlpool RBD277PDB4
Whirlpool RBD277PDQ1
Whirlpool RBD277PDQ2
Whirlpool RBD277PDQ4
Whirlpool RBD305PDB1
Whirlpool RBD305PDB10
Whirlpool RBD305PDB11
Whirlpool RBD305PDB12
Whirlpool RBD305PDB13
Whirlpool RBD305PDB14 30" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD305PDB15 30" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD305PDB2
Whirlpool RBD305PDB3
Whirlpool RBD305PDB4
Whirlpool RBD305PDB6
Whirlpool RBD305PDB7
Whirlpool RBD305PDB8
Whirlpool RBD305PDB9
Whirlpool RBD305PDQ1
Whirlpool RBD305PDQ10
Whirlpool RBD305PDQ11
Whirlpool RBD305PDQ12
Whirlpool RBD305PDQ13
Whirlpool RBD305PDQ14 30" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD305PDQ15 30" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD305PDQ2
Whirlpool RBD305PDQ3
Whirlpool RBD305PDQ4
Whirlpool RBD305PDQ6
Whirlpool RBD305PDQ7
Whirlpool RBD305PDQ8
Whirlpool RBD305PDQ9
Whirlpool RBD305PDS12
Whirlpool RBD305PDS14 30" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD305PDS15 30" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD305PDT11
Whirlpool RBD305PDT12
Whirlpool RBD305PDT13
Whirlpool RBD305PDT14 30" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD305PDT15 30" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD305PRB00 24" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD305PRQ00 24" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD305PRS00 24" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD305PRT00 24" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD306PDB1
Whirlpool RBD306PDB10
Whirlpool RBD306PDB11
Whirlpool RBD306PDB12
Whirlpool RBD306PDB13
Whirlpool RBD306PDB14 30" Built - in Electric Double Oven Self - Clean Upper and Lower Ovens
Whirlpool RBD306PDB15 30" Built - in Electric Double Oven Self - Clean Upper and Lower Ovens
Whirlpool RBD306PDB2
Whirlpool RBD306PDB4
Whirlpool RBD306PDB6
Whirlpool RBD306PDB7
Whirlpool RBD306PDB8
Whirlpool RBD306PDB9
Whirlpool RBD306PDQ1
Whirlpool RBD306PDQ10
Whirlpool RBD306PDQ11
Whirlpool RBD306PDQ12
Whirlpool RBD306PDQ13
Whirlpool RBD306PDQ14 30" Built - in Electric Double Oven Self - Clean Upper and Lower Ovens
Whirlpool RBD306PDQ15 30" Built - in Electric Double Oven Self - Clean Upper and Lower Ovens
Whirlpool RBD306PDQ2
Whirlpool RBD306PDQ4
Whirlpool RBD306PDQ6
Whirlpool RBD306PDQ7
Whirlpool RBD306PDQ8
Whirlpool RBD306PDQ9
Whirlpool RBD306PDT11
Whirlpool RBD306PDT12
Whirlpool RBD306PDT13
Whirlpool RBD306PDT14 30" Built - in Electric Double Oven Self - Clean Upper and Lower Ovens
Whirlpool RBD306PDT15 30" Built - in Electric Double Oven Self - Clean Upper and Lower Ovens
Whirlpool RBD306PDZ1
Whirlpool RBD306PDZ10
Whirlpool RBD306PDZ2
Whirlpool RBD306PDZ4
Whirlpool RBD306PDZ6
Whirlpool RBD306PDZ7
Whirlpool RBD306PDZ8
Whirlpool RBD306PDZ9
Whirlpool RBD307PDB1
Whirlpool RBD307PDB2
  #2 (permalink)
Old 04-17-2009, 04:27 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Replacement parts for WHIRLPOOL RBD275PDT10 | AppliancePartsPros.com
Here is a tech sheet and a service manual
https://www.servicematters.com/docs/...%204451887.pdf
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/7d69e72584ddde3385256a7e00524e76/$FILE/8178007.pdf
Possible. Or it could be that the ribbon cable was not all the way in the connector when it was locked in. But since you are getting the same error code as the original fault this is doubtful. Could try cleaning the connector on the control board (see below), also check that the pins in the connector look OK. A magnifying glass will help. Sounds like you may have a bad solder joint or a cracked track on the control board. Remove the control board and wiggle the ribbon cable connector while looking at the back side of the board to see if any of the pins move. Bad solder joints often have a dull color or pin holes. Again a magnifying glass helps.
I doubt this a bad transformer would most likely kill all power to the control board.
May have to do this if you cannot find a bad connection and cleaning does not help.
RIBBON CABLE CLEANING
Unplug the unit
Open it up
Remove the ribbon cable from the keypad to the control board at the control board.
Clean the edge connector.
If it is the type where there is not a connector just the insulation is removed, it can be cleaned with a pencil eraser. Do not use an ink eraser as it is too abrasive.
Check the tracks in the ribbon cable for hairline cracks. A magnifying glass helps here.
Would not hurt to clean the connector on the board. Use electronics contact cleaner or isopropyl alcohol and a tooth brush. Be gentle and do not reconnect till all the solvent evaporates.
Reconnect everything and give it a try.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Temperature Control & Fault Codes alex_ny Oven Repair (including Ranges and Cooktops) 0 06-06-2009 06:50 AM
Fault Codes and Beeps hesper73 Oven Repair (including Ranges and Cooktops) 1 03-31-2009 06:41 AM
Dryer Fault Codes kayyjohnston Dryer Repair 1 01-08-2009 05:15 AM
unable to access F1 sub fault codes mr2clutz Oven Repair (including Ranges and Cooktops) 1 10-27-2008 01:12 PM
Appliance Color Codes bentwrench1999 Washer Repair 0 02-26-2008 12:50 PM
