During cooking an error code appeared (E2 F3) and the oven locked itself. I finally got the oven to open and looked up the error code. It said that I needed to replace the temperature sensor, so I did that.
Upon the first reheat after replacing the sensor, the same thing happened and the same error code appeared.
The manual doesn't provide any information about the error codes at all, and in general doesn't seem helpful. Any more information would be great.
Thanks, Laney
