Discuss
Magic chef oven 6498vrv
 in
My magic chef oven model#6498vrv is not maintaing proper temperature. I have replaced the oven sensor. Then checked oven
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Magic chef oven 6498vrv
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 12-02-2007, 05:57 AM
michaelman31 michaelman31 is offline
Junior Member
michaelman31 is on a distinguished road
Default Magic chef oven 6498vrv
Model Number: 6498vrv   Brand: Magic Chef   Age: More than 10 years
My magic chef oven model#6498vrv is not maintaing proper temperature. I have replaced the oven sensor. Then checked oven temperature with a thermometer and temperature is off by 200-300 degrees. Last year I replaced the touch panel , which fine. I have searched for other parts that might be the problem, I found Relay board
Part Number: AP379876 made by MAYTAG could this be needed? Any other suggestions or parts would be greatly appreciated. I'm sure there is a thermastat somewhere built into a part, could that relay board be it ?
Thank You Michaelman31
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 12-02-2007, 10:45 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Most likely the problem with your oven is a bad control board (aka clock).
This is the part which operates with the relay board due the oven sensor readings.
- The part number for the clock AP382949
- Here are the break down diagrams for the Magic Chef range Model 6498VRV
__________________
Professional appliance repair services in Orange County, California.
  #3 (permalink)
Old 12-04-2007, 01:55 PM
Junior Member
Default
Thank you Gene , is the thermastat in the control panel (clock) ? DO you have a wiring schematic? Thanks again for your help Michaelman
  #4 (permalink)
Old 12-04-2007, 02:44 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Your oven does not have any thermostats, just the control board.
Unfortunately I do not have the wiring diagram for your oven.
__________________
  #5 (permalink)
Old 12-04-2007, 04:23 PM
Junior Member
Default
Thank you Gene.I will order the control panel .
  #6 (permalink)
Old 12-04-2007, 07:03 PM
ripleys ripleys is offline
Senior Expert
APP Volunteer
ripleys is on a distinguished road
Default
Yes Gene is 100% correct on diagnosing the clock. Maytag (Magic Chef) clocks are known for going eratic in the temperature department.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Magic Chef Oven Not Turning On COLORICAN Oven Repair (including Ranges and Cooktops) 2 11-26-2007 07:40 AM
Magic Chef oven top element not working charlotte Oven Repair (including Ranges and Cooktops) 0 11-25-2007 09:42 AM
magic chef oven igniter - stopped working bdjdcole Oven Repair (including Ranges and Cooktops) 1 11-14-2007 09:11 PM
Magic Chef gas oven won't light koohgar Oven Repair (including Ranges and Cooktops) 10 10-17-2007 02:00 PM
Magic Chef washer won't spin wixomdave Washer Repair 0 10-11-2007 07:25 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
