Appliance Repair Forum
-   Oven Repair (including Ranges and Cooktops) (http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/)
-   -   Oven door does not lock to begin clean cycle (http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/304846-oven-door-does-not-lock-begin-clean-cycle.html)
bread-baker 09-17-2011 09:21 PM
When I set the oven to clean cycle and set the time, the clean indicator comes on and the lock indicator also comes on but the door does not lock. As a result, after about 30 seconds, the "door" indicator comes on and the unit cancels the clean cycle.
Could there be a mechanical problem or is this the relay? If it's an electronics problem, is the only solution to replace the relay board?
Thank you for your help.
bread-baker
