stove control works can't see display what part should i order
Originally Posted by: Miguel Hernandez stove control works can't see display what part should i order Miguel, You'll need to check the wiring harness between the ERC and Relay board. If the wires are OK, you'll need to order and install the display repair kit Part number: AP4929089
Thanks, :) :) :)
