| » Maytag Wall Oven Control Panel |
Model Number: CWE9000BCB Brand: Maytag Age: More than 10 years
I just received a new control panel p/n WPL 74001423. This is the 4th one for this oven - they seem to fail after a few years with a "F1" error and changing the control panel fixes it for a while.
The new panel appears identical to the bad one except for the connector on the end of the ribbon cable. The new one just has the flat, slide in cable with two square holes on the end. The old one has a similar cable, but it has a molded connector with pins that plugs into a matching connector with holes. This pin connector is not removable from the cable without destroying something. Can anyone help me get the correct panel or a connector to use with the one I was shipped, please? This is the fifth panel for this oven, I think. The original seller replaced one, I replaced two. I don't recall any problem with them. Thanks in advance for your help. Best Regards, Dave Chaney Baton Rouge, LA Ads By Google Related Models |
| Display Modes | |
| Whirlpool Wall Oven Control Panel | hkelman | Oven Repair (including Ranges and Cooktops) | 3 | 04-23-2011 05:20 PM |
| Part number for Maytag oven control panel? | citulsja | Oven Repair (including Ranges and Cooktops) | 4 | 06-03-2010 09:30 PM |
| Jenn-air wall oven control panel noty working | fritz | Oven Repair (including Ranges and Cooktops) | 5 | 10-12-2009 09:46 PM |
| Need electronic control panel for wall oven | tankersm | Oven Repair (including Ranges and Cooktops) | 2 | 01-01-2008 10:05 AM |
| Maytag Electronic Oven Control Panel | MDB | Oven Repair (including Ranges and Cooktops) | 2 | 12-07-2007 03:28 PM |
