I have Maytag range “Precision Touch Control 500 Electric Smoothtop” Model number: MER576508W and serial number: 18720704GE A few days ago oven stopped heating properly. It takes over 2 hours to get up to 240 degrees. I have no idea what is causing this and hope you can advise me how to fix the problem. Thanks
Cannot find any info using the given model number MER576508W
I can find info on MER5765 but they have the letters after this and no numerals. Please check your model number.
Check to see if both the bake and broil elements both come on in preheat.
Is it just an oven or a stove. If a stove do the cook top elements run OK.
If just an oven flip your breaker off/on slowly a couple times. You may not have the full 240 volts required. Sometimes you can loose half the line without actually tripping the breaker.
THIS FORUM IS DEAD!!!!!!! |
