Discuss
Downdraft fan turns on automatically when gas burner is turned on
 in
I have a Jenn Air gas stove with a built in down draft fan. When I ignite either of the
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Downdraft fan turns on automatically when gas burner is turned on
  #1 (permalink)
Old 09-15-2011, 07:19 AM
Junior Member
bigjake111 is on a distinguished road
Default Downdraft fan turns on automatically when gas burner is turned on
Brand: Jenn-Air   Age: More than 10 years
I have a Jenn Air gas stove with a built in down draft fan. When I ignite either of the burners on the left side the fan turns on automatically to the high setting and it can't be shut it off without shutting off the burners on the left side of the stove. This doesn't happen with the 2 right sided burners. How do I fix this?
  #2 (permalink)
Old 10-13-2011, 11:11 AM
Junior Member
storm965 is on a distinguished road
Default
I have a Jenn Air also that does the same thing. However, if you can slide the burners to the front it will turn off the down draft fan. At least, that is how my stove works. Good luck!
  #3 (permalink)
Old 10-14-2011, 06:32 AM
Joe / APP Team's Avatar
Senior Expert
Joe / APP Team is on a distinguished road
Default
Quote:
Bigjake,
If you have the "E" burner (barbque grille) in the left bay, that is normal operation.
If you have the two burner conversion kit in the left bay, You will need to check the bypass tongue on the bottom of the araeation(drip) pan and adjust it to activate the by pass switch for the down draft fan.
Thanks and Good Luck,
__________________
Thanks for allowing AppliancePartsPros.com to assist you,
Joe M. APP TEAM
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #4 (permalink)
Old 11-19-2012, 05:16 PM
Junior Member
vudean is on a distinguished road
Red face
Quote:
Originally Posted by Joe / APP Team View Post
Bigjake,
Can you repeat that second sentence in English? Are you saying if I buy the burners I can turn this "feature" off? Can I turn it off either way? I sure don't need a fan blowing on high while boiling water!
  #5 (permalink)
Old 11-20-2012, 06:25 AM
Senior Expert
Default
Quote:
Vudean, If you have a Jenn Air "gas" range or cooktop, with a down draft fan, it is designed to activate the down draft fan, whenever the left side bay switches are on, The left side bay is a "grille" for "bar be quing" If you purchase and install a burner conversion kit
Part number: AP4122839
the areation pan (drip pan) has a "tongue" or lever on the bottom, that when you install the pan, the lever activates a"by pass" switch, that deactivates the down draft fan motor, and you'll have to manually activate the down draft motor with the switch on the control panel. Thanks
__________________
Joe M. APP TEAM
  #6 (permalink)
Old 08-04-2014, 05:08 PM
Junior Member
jejocrane is on a distinguished road
Default
I'm having the same problem with my Jenn-Aire model # JDS9860BDS. I removed the cartridge and did not see a "tongue" or lever. Do you have to remove the drip pan to find the "tongue" or lever on the bottom to bypass the activation switch? I did not remove the drip pan but used a flashlight and mirror to inspect the underside and did not see the lever you describe.
  #7 (permalink)
Old 08-18-2014, 08:43 AM
Senior Expert
Default
Quote:
jejocrane, Thank you for the model number of your range. Your range is slightly different than the previous posts(they forgot to attach a model number).
In your case, you have to remove the complete dual burner cartridge,
Part number: AP5804347
Once removed, you should "see" the plunger of the "Snap Switch"
Part number: AP4099548
Protruding from the front bay wall. You'll need to check that the plunger is working and the switch assembly isn't loose or out of adjustment.
When you insert the burner cartridge assembly and it is seated and attached properly, the base housing of the cartridge should contact the plunger and press the plunger in, to bypass the down draft fan motor circuit.
__________________
Joe M. APP TEAM
  #8 (permalink)
Old 02-03-2015, 07:09 PM
Junior Member
dmulvi5 is on a distinguished road
Default
Is there any way to engage the bypass switch without buying the burner converter?
  #9 (permalink)
Old 02-04-2015, 07:04 AM
Senior Expert
Default
Quote:
dmulvi, Some people / servicers would just bypass the switch. But that could be a little dangerous in the even of a spill over or short in the wiring.
We wish we knew what you have in mind, the downdraft fan is used to remove the smoke, grease, etc. when cooking on the left side grille burner.
__________________
Joe M. APP TEAM
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
burner heating up while not turned on BK1234 Oven Repair (including Ranges and Cooktops) 1 08-04-2011 03:25 AM
Microwave Turns on automatically foxx_ Microwave Repair 0 08-23-2009 03:19 AM
F4/F3 Error Sensor; Turns on automatically and beeps jnchay Microwave Repair 0 05-03-2009 09:31 AM
New clock returns to 12:00 when top burner is turned on swilk2 Oven Repair (including Ranges and Cooktops) 0 04-24-2009 10:44 AM
microwave turns on automatically, no timer, no heat Michael Nguyen Microwave Repair 1 04-08-2009 08:19 PM
