I replaced the temp sensor after a cleaning cycle did not finish, but the control panel and the fan were still running. The door was not locked. This is the second time in two months that I have replaced the sensor. The first time I turned the oven on but neither element would heat. After replacing the sensor, everything worked fine. Not this time. Again neither element will heat up. Any thoughts from anyone?
THIS FORUM IS DEAD!!!!!!! |
