Discuss
replacing oven control panel
 in
I have a frigidaire oven with a bad control panel or some call it electronic timer.I want to know
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » replacing oven control panel
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 08-02-2007, 01:04 PM
brad brad is offline
Junior Member
brad is on a distinguished road
Unhappy replacing oven control panel
Model Number: fefb67bhwa   Brand: Frigidaire   Age: 5 - 10 years
I have a frigidaire oven with a bad control panel or some call it electronic timer.I want to know if i replace it will it work by simply replacing it or does it need some special programing after it is installed? The motor latch assembly is also bad that opens and closes the door when it is in clean mode if i dont replace this will the oven still work as long as i dont use the clean cycle.Also ithe locking rod easy easy acessed from under the range top could i just turn it to locked and clen it and turn it back after it has finished and cooled down.Just trying to go the cheapest route.I know this is whats wrong because i took it to a frigidaire repair place but they wanted $460 to replace everything and i could buy a new one for that.I can get the control panel on your site for $190 and the motor latch assembly for $75 but would rather not replace this if i dont need to. thank you brad
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 08-02-2007, 04:31 PM
Admin / APP Team Admin / APP Team is offline
Administrator
APP Team
Admin / APP Team has disabled reputation
Default
Brad,
As far as replacing the control board, it's a simple changeout. There is no need for any programming - "plug and play".
And as far as the motor latch assembly, if you keep the bad one in, it may (or may not) trigger an error code on the control board and you won't be able to use the oven. I can't really comment on manually releasing the locking rod. Not because I want you to spend the money on the new latch assembly, but because: 1. it's not really a safe option 2. liability issues.
  #3 (permalink)
Old 07-14-2008, 02:55 PM
jhred jhred is offline
Junior Member
jhred is on a distinguished road
Default Simple?? I'm stuck on removing clock/timer.
I have taken the back off of the top back of the range, model fgf354, and I can see the timer/clock. Now what? It doesn't seem to want to come out and is driving me nuts. Wife is on me to geterdone. Help.
Jay
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Replacing door panel & handle Laurence Microwave Repair 2 01-13-2008 08:09 PM
Electronic Oven Control andye Oven Repair (including Ranges and Cooktops) 3 08-01-2007 07:45 AM
oven/broiler control unit dynaguy Oven Repair (including Ranges and Cooktops) 1 07-31-2007 04:36 PM
Taking dryer panel off debmin Dryer Repair 1 07-26-2007 08:34 PM
Replacing Control Panel bhandg Oven Repair (including Ranges and Cooktops) 2 07-23-2007 04:30 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
