Turn Oven On Bake, Set Desired Temp (say 450) Then Oven Begins To Slowly Heat And Goes Up To 275 After 45 Minutes And That Is As Far As It Will Go Even If It Sits Thee For Two Hours.
Originally Posted by: delbert payne Turn Oven On Bake, Set Desired Temp (say 450) Then Oven Begins To Slowly Heat And Goes Up To 275 After 45 Minutes And That Is As Far As It Will Go Even If It Sits Thee For Two Hours. JENN AIR MODEL 800 TOUCH CONTROL OVEN ISSUES. TURN OVEN ON BAKE, BAKE LIGHTS UP, SET CLOCK TO 450 NO PROBLEM THEN WHEN OVEN BEGINS BAKE CYCLE IT GOES UP TO 275 AFTER 45 MINUTES AND THAT IS AS FAR AS IT WILL GO
