Discuss
Electrolux Slide in Range error code
 in
Error code 5F appeared while cooking this morning. I have turned power off and on after 5 minutes. Still shows
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Electrolux Slide in Range error code
  #1 (permalink)
Old 09-12-2011, 06:07 AM
Junior Member
korniemd is on a distinguished road
Default Electrolux Slide in Range error code
Model Number: EW30ES65GS   Brand: Electrolux   Age: 1 - 5 years
Error code 5F appeared while cooking this morning. I have turned power off and on after 5 minutes. Still shows code and no ability to control anything. Can't find this code listed anywhere.
Related Models
 EW30ES65GSA ELECTRIC RANGE
 EW30ES65GSB ELECTRIC RANGE
 EW30ES65GSC ELECTRIC RANGE
 EW30ES65GSD ELECTRIC RANGE
 EW30ES65GSE ELECTRIC RANGE
 EW30ES65GSF ELECTRIC RANGE
 EW30ES65GSG ELECTRIC RANGE
 EW30ES65GWA ELECTRIC RANGE
 EW30ES65GWB ELECTRIC RANGE
 EW30ES65GWC ELECTRIC RANGE
 EW30ES65GWD ELECTRIC RANGE
 EW30ES65GWE ELECTRIC RANGE
 EW30ES65GWF ELECTRIC RANGE
 EW30ES6CGB1 ELECTRIC RANGE
 EW30ES6CGB2 ELECTRIC RANGE
 EW30ES6CGS1 ELECTRIC RANGE
 EW30ES6CGS2 ELECTRIC RANGE
 EW30ES6CGS3 ELECTRIC RANGE
 EW30ES6CGS4 ELECTRIC RANGE
 EW30ES6CGS5 ELECTRIC RANGE
 EW30ES6CGS6 ELECTRIC RANGE
 EW30ES6CGS7 ELECTRIC RANGE
 EW30ES6CGW1 ELECTRIC RANGE
 EW30ES6CGW2 ELECTRIC RANGE
 EW30EW55GB1 WALL OVEN
 EW30EW55GB2 WALL OVEN
 EW30EW55GB3 WALL OVEN
 EW30EW55GB4 WALL OVEN
 EW30EW55GB5 WALL OVEN
 EW30EW55GB6 WALL OVEN
 EW30EW55GS1 WALL OVEN
 EW30EW55GS2 WALL OVEN
 EW30EW55GS3 WALL OVEN
 EW30EW55GS4 WALL OVEN
 EW30EW55GS5 WALL OVEN
 EW30EW55GS6 WALL OVEN
 EW30EW55GS7 WALL OVEN
 EW30EW55GW1 WALL OVEN
 EW30EW55GW2 WALL OVEN
 EW30EW55GW3 WALL OVEN
 EW30EW55GW4 WALL OVEN
 EW30EW55GW5 WALL OVEN
 EW30EW55GW6 WALL OVEN
 EW30EW5CGB1 WALL OVEN
 EW30EW5CGB3 WALL OVEN
 EW30EW5CGB4 WALL OVEN
 EW30EW5CGS1 WALL OVEN
 EW30EW5CGS2 WALL OVEN
 EW30EW5CGS3 WALL OVEN
 EW30EW5CGS6 WALL OVEN
 EW30EW5CGS7 WALL OVEN
 EW30EW5CGW1 WALL OVEN
 EW30EW5CGW3 WALL OVEN
 EW30EW5CGW4 WALL OVEN
 EW30EW65GB1 WALL OVEN
 EW30EW65GB2 WALL OVEN
 EW30EW65GB3 WALL OVEN
 EW30EW65GB4 WALL OVEN
 EW30EW65GB5 WALL OVEN
 EW30EW65GB6 WALL OVEN
 EW30EW65GB7 WALL OVEN
 EW30EW65GS1 WALL OVEN
 EW30EW65GS2 WALL OVEN
 EW30EW65GS3 WALL OVEN
 EW30EW65GS4 WALL OVEN
 EW30EW65GS5 WALL OVEN
 EW30EW65GS6 WALL OVEN
 EW30EW65GS7 WALL OVEN
 EW30EW65GS8 ELECTROLUX/WALL OVEN
 EW30EW65GW1 WALL OVEN
 EW30EW65GW2 WALL OVEN
 EW30EW65GW3 WALL OVEN
 EW30EW65GW4 WALL OVEN
 EW30EW65GW5 WALL OVEN
 EW30EW65GW6 WALL OVEN
 EW30EW65GW7 WALL OVEN
 EW30EW6CGB1 WALL OVEN
 EW30EW6CGB3 WALL OVEN
 EW30EW6CGS3 WALL OVEN
 EW30EW6CGS4 WALL OVEN
 EW30EW6CGS5 WALL OVEN
 EW30EW6CGS6 WALL OVEN
 EW30EW6CGS7 WALL OVEN
 EW30EW6CGS8 WALL OVEN
 EW30EW6CGW1 WALL OVEN
 EW30EW6CGW3 WALL OVEN
 EW30GC55GB1 COOKTOP
 EW30GC55GB2 COOKTOP
 EW30GC55GS1 COOKTOP
 EW30GC55GS2 COOKTOP
 EW30GC55GW1 COOKTOP
 EW30GC55GW2 COOKTOP
 EW30GC60IS1 COOKTOP
 EW30GC60IS2 COOKTOP
 EW30GF65GBA GAS RANGE
 EW30GF65GBB GAS RANGE
 EW30GF65GBC GAS RANGE
 EW30GF65GBD GAS RANGE
 EW30GF65GBE GAS RANGE
 EW30GF65GSA GAS RANGE
 EW30GF65GSB GAS RANGE
 EW30GF65GSC GAS RANGE
 EW30GF65GSD GAS RANGE
 EW30GF65GSE GAS RANGE
 EW30GF65GSF GAS RANGE
 EW30GF65GSG GAS RANGE
 EW30GF65GSH GAS RANGE
 EW30GF65GSJ GAS RANGE
 EW30GF65GSK GAS RANGE
 EW30GF65GWA GAS RANGE
 EW30GF65GWB GAS RANGE
 EW30GF65GWC GAS RANGE
 EW30GF65GWD GAS RANGE
 EW30GF65GWE GAS RANGE
 EW30GS65GB1 GAS RANGE
 EW30GS65GB2 GAS RANGE
 EW30GS65GB5 GAS RANGE
 EW30GS65GB6 GAS RANGE
 EW30GS65GB7 GAS RANGE
 EW30GS65GB8 GAS RANGE
  #2 (permalink)
Old 06-01-2013, 02:45 PM
Junior Member
AZ Ed is on a distinguished road
Smile Electrolux "5F" error message
This just happened to my 2008 Electrolux slide in range with Wave Control. I found a posting on "FixYa.com", and a solution that worked!
Simply press the + and - (Plus and Minus) - keys on the bottom of the numeric keypad simultaneously for 3 seconds. This resets the display panel for the range top to the factory default settings. Then reset the clock per the user manual, and you should be OK. Caused by temperatures on the glass top falling outside of the ranges expected by the display controls, and the control shuts itself off until it is reset to the factory defaults. In our case, a guest put a hot pot on the glass top straddling three burners. Oh well...
The service technician we called didn't know of this fix, and I can't find it on other posts; but it saved me $650 because I didn't have to replace the stove top display board.
Post if this works for you please.
  #3 (permalink)
Old 06-14-2013, 08:41 PM
Junior Member
Smile Electrolux Range Error code 5F
Quote:
Hold down the + and - (plus and minus) buttons on the bottom of the numeric keypad for 3 to 5 seconds. The displays will reset to the factory default setting, and your are back in business
  #4 (permalink)
Old 07-08-2013, 04:44 AM
Junior Member
ashley13 is on a distinguished road
Smile This solution WORKS!!!
This solution solved my problem. After frying wings the some hot grease cause the oven to lock and I couldn't cancel. After reading this post, I tried it and it WORKED!! Thanks a million.
  #5 (permalink)
Old 04-09-2017, 01:05 AM
Junior Member
kellygirl is on a distinguished road
Smile Re-setting control panel
I received an E 15 error code on Electrolux slide in Induction range. I had already done the unplug reset and the breaker box reset. That did not work. So..to the the internet I went
I began shopping around for another induction range after reading several posts on other sites. It seemed hopeless and VERY expensive to TRY to figure out what the problem is.
Enter AppliancePartsPro.
I am so grateful to have found the post that suggested to hold down the - and the
+ (just below the numbers) at the same time for 3 to 5 seconds. I did the hold for 10 for good measure.
It has been just about 25 minutes and no error code and that annoying beeping are gone. IT WROKED!! My Induction range has been reset to factory settings.
I can't tell you how happy I am. I just had a night mare of a move into an old house that has already put me in the hole 30K. The thought of spending any more money...just about put me over the edge.
Oh and a FYI- One post mentioned excessive heat being created on the glass top. I do believe that was what set off the problem. i had the oven at 450 and I used the power boost at the same time. I WONT DO THAT AGAIN.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
error code PF when i try to use my range MikkiJ24 Oven Repair (including Ranges and Cooktops) 0 10-10-2010 03:18 PM
Electrolux Slide-in electric range overheats kbrubaker Oven Repair (including Ranges and Cooktops) 0 09-25-2010 06:35 AM
Range error code mattress68 Oven Repair (including Ranges and Cooktops) 0 05-03-2009 03:33 PM
GE Gas Range Error Code F1 RiverFisher Oven Repair (including Ranges and Cooktops) 1 01-09-2009 07:42 AM
F1 error on Amana slide in Range lmunson Oven Repair (including Ranges and Cooktops) 3 10-10-2008 09:19 PM
