Subsequent to a power outage the clock did not keep time properly. Did a power reset via breakers and clock works normally however now the oven does not keep the select T: I set 350FF the oven will heat up to 350F but will not maintain it. Temperature will eventually drop to 280F and stay there. I've done a second power reset to no avail.
Any suggestions?
Raymond
