Discuss
Jenn-Air Cooktop
 in
I have a jenn_air cooktop that is has all the ignitors firing anytime the unit is plugged in. It continues
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Jenn-Air Cooktop
  #1 (permalink)
Old 09-10-2011, 10:55 AM
Junior Member
A. Scott is on a distinguished road
Default Jenn-Air Cooktop
Model Number: JGD8345   Brand: Jenn-Air   Age: 1 - 5 years
I have a jenn_air cooktop that is has all the ignitors firing anytime the unit is plugged in. It continues to fire after the individual burner has started burning. This happens at all burners at the same time. In researching this the problem seems to be caused by a "Spark Module", however, I find two of them on the parts lists. One is a mfg # of 8215557 and the other is mfg# 74008821. Which one corrects this problem? By the way, where is the problem module located?
Ads By Google
Related Models
Jenn-Air JGD8345ADB Surface Unit - Ddraft Gas
Jenn-Air JGD8345ADW Surface Unit - Ddraft Gas
Jenn-Air JGD8348ADP Surface Unit - Ddraft Gas
Jenn-Air JGD8348BDP Surface Unit - Ddraft Gas
Jenn-Air JGD8348CDP Surface Unit - Ddraft Gas
Jenn-Air JGD8430ADB Surface Unit - Ddraft Gas
Jenn-Air JGD8430ADF Surface Unit - Ddraft Gas
Jenn-Air JGD8430ADN Surface Unit - Ddraft Gas
Jenn-Air JGD8430ADS Surface Unit - Ddraft Gas
Jenn-Air JGD8430ADW Surface Unit - Ddraft Gas
General Electric JGDS10GER1WH Gas range
General Electric JGHC56GEH1 Hi-low range
General Electric JGHC56GEH2 Gas range
General Electric JGHC56GEH3 Gas range
General Electric JGHC56GEJ1 Hi-low range
General Electric JGHC56GEJ2 Gas range
General Electric JGHC56GEJ3 Gas range
General Electric JGHC56GEJ4 Gas range
General Electric JGHC56GEJ5 Gas range
General Electric JGHC56GEJ6 Gas range
General Electric JGHC56GEJ7 Gas range
General Electric JGHC56GEJ8 Gas range
General Electric JGHC56GEJC Electric range
General Electric JGHC56GEJD Electric range
General Electric JGHC56GEJE Gas range
General Electric JGHC60GEH1 Gas range
General Electric JGHC60GEH2 Gas range
General Electric JGHC60GEH3 Gas range
General Electric JGHC60GEJ1 Gas range
General Electric JGHC60GEJ2 Gas range
General Electric JGHC60GEJ3 Gas range
General Electric JGHC60GEJ4 Gas range
General Electric JGHC60GEJ5 Gas range
General Electric JGHC60GEJ6 Gas range
General Electric JGHC60GEJ7 Electric range
General Electric JGHC60GEN6 Electric range
General Electric JGHC60GEN7 Gas range
General Electric JGHC66GEH1 Gas range
General Electric JGHP57GEJ1
General Electric JGHP57GEJ10 Gas range
General Electric JGHP57GEJ2 Gas range
General Electric JGHP57GEJ3 Gas range
General Electric JGHP57GEJ4 Gas range
General Electric JGHP57GEJ5 Gas range
General Electric JGHP57GEJ6 Gas range
General Electric JGHP57GEJ7 Gas range
General Electric JGHP57GEJ8 Gas range
General Electric JGHP57GEJ9 Gas range
General Electric JGHP57GEJB Gas range
General Electric JGHP57GEJC Gas range
General Electric JGHP57GEJD Gas range
General Electric JGHP57GEJE Electric range
General Electric JGHP57GEJF Electric range
General Electric JGHP57GEJG Electric range
General Electric JGHP66GEH1 Gas range
General Electric JGHP66GEH2 Gas range
General Electric JGHP66GEH3 Gas range
General Electric JGHP66GEJ1
General Electric JGHP66GEJ10 Gas range
General Electric JGHP66GEJ2 Gas range
General Electric JGHP66GEJ3 Gas range
General Electric JGHP66GEJ4 Gas range
General Electric JGHP66GEJ5 Gas range
General Electric JGHP66GEJ6 Gas range
General Electric JGHP66GEJ7 Gas range
General Electric JGHP66GEJ8 Gas range
General Electric JGHP66GEJ9 Gas range
General Electric JGHP66GEN4 Electric range
General Electric JGHP66GEN5 Electric range
General Electric JGHP66GEN7
General Electric JGKC15GEH1 Gas range
General Electric JGKC15GEH2 Gas range
General Electric JGKC15GEH3 Gas range
General Electric JGKC16GEH1 Gas range
General Electric JGKC16GEH2 Gas range
General Electric JGKC16GEH3 Gas range
General Electric JGKS15GEH1 Gas range
Maytag JGM2224 Commercial Cooking
Maytag JGM2236 Commercial Cooking
Maytag JGM2248 Commercial Cooking
Maytag JGM2272 Commercial Cooking
Maytag JGM2284 Commercial Cooking
General Electric JGP18BEVBB Range accessory
General Electric JGP300EH1 Electric range
General Electric JGP300EJ1 Electric range
General Electric JGP300EK1 Electric range
General Electric JGP310EH1 Electric range
General Electric JGP310EJ1 Electric range
General Electric JGP310EK1 Gas range
General Electric JGP319EJ1CT Gas range
General Electric JGP319EJ1WH Gas range
General Electric JGP319EP1 Gas range
General Electric JGP319EP2AD Gas range
General Electric JGP319EP2HA Gas range
General Electric JGP319EP2WH Gas range
General Electric JGP319EP3AD Gas range
General Electric JGP319EP3HA Gas range
General Electric JGP319EP3WH Gas range
General Electric JGP319EV1AD Gas range
General Electric JGP319EV1CT Gas range
General Electric JGP319EV1WH Gas range
General Electric JGP320EP1 Gas range
General Electric JGP320EP2AD Gas range
General Electric JGP320EP2WH Gas range
General Electric JGP320EP3AD Gas range
General Electric JGP320EP3WH Gas range
General Electric JGP320ER1 Gas range
General Electric JGP320ER2BL Gas range
General Electric JGP320ER3BL Gas range
General Electric JGP320EV1BL Gas range
General Electric JGP320EV1WH Gas range
General Electric JGP320EV2BL Gas range
General Electric JGP321EJ1BL Gas range
General Electric JGP321EJ1WH Gas range
General Electric JGP321EP1 Gas range
General Electric JGP321EP2BC Gas range
General Electric JGP321EP3BC Gas range
General Electric JGP325ER1WH Gas range
General Electric JGP325ER2WH Gas range
General Electric JGP325ER3WH Gas range
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Jenn-air cooktop Hankstabler Oven Repair (including Ranges and Cooktops) 0 07-10-2011 01:06 PM
Jenn-air Radiant Cooktop wdalton Oven Repair (including Ranges and Cooktops) 0 06-27-2011 03:29 PM
Jenn Air Cooktop Joepa7 Oven Repair (including Ranges and Cooktops) 0 04-11-2011 01:08 PM
Jenn-air cooktop starters ratherboffroad Oven Repair (including Ranges and Cooktops) 0 12-24-2010 03:33 PM
Old Jenn-Air Cooktop fredringwald Oven Repair (including Ranges and Cooktops) 3 06-19-2009 03:04 PM
