Discuss
Oven temperature is irregular
 in
My oven gets either too hot or not hot enough. I don't know if its the sensor or the
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Oven temperature is irregular
  #1 (permalink)
Old 11-29-2007, 08:45 PM
jm605 jm605 is offline
Junior Member
jm605 is on a distinguished road
Default Oven temperature is irregular
Model Number: SF377PEGB5   Brand: Whirlpool   Age: 5 - 10 years
My oven gets either too hot or not hot enough. I don't know if its the sensor or the control panel but there seems to be some type of electrical problem. It preheats to the temperature and then either cools down or heats up too high so baking anything either takes hours or minutes. Any help at all would be appreciated. Thanks.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 11-29-2007, 09:00 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Most likely the problem with your oven is a bad control board but if it cools down after preheated, the bake burner could be bad too.
- The part number for the control board (black) AP3841165
- The part number for the control board (white) AP3841218
- The part number for the bake burner AP3598752
- Here are the break down diagrams for the Whirlpool range Model SF377PEGB5
__________________
Professional appliance repair in Los Angeles, California.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Oven not keeping correct Temperature Andrew Mail Oven Repair (including Ranges and Cooktops) 1 11-27-2007 04:34 PM
Whirlpool Wall Oven (self cleaning) will not hold temperature araki Oven Repair (including Ranges and Cooktops) 1 11-14-2007 08:13 PM
Oven will not heat to correct temperature Luapam Oven Repair (including Ranges and Cooktops) 1 11-14-2007 11:19 AM
GE Oven not reaching temperature Dave Roce Oven Repair (including Ranges and Cooktops) 0 10-18-2007 02:00 PM
Old Caloric Oven: irregular ignition and won't hold a temperature mhrichardson99 Oven Repair (including Ranges and Cooktops) 0 08-23-2007 10:20 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
