| » GE double oven |
Model Number: JKP37G0L1WG Brand: GE Age: More than 10 years
Gentlemen, I hope you can help me. I have an electric GE double oven that is about 15 years old. Several weeks ago, I discovered the broiler was not heating. I examined the the element and saw a blister on it and ordered a new broiler element. My wife used the oven self cleaning mode before I received the element. The oven went through the clean cycle just fine. I switched on the just oven last night and the broiler element came on. When I switched it to broil, it did not heat. Has the oven switch failed internally? Have you ever seen a failure like this? Thanks for any help you can provide.
Regards, Jim |
The first thing I would check are the knobs for the oven thermostat and the selector switch.
The knob consists of two pieces: the outer part with the temperature settings (or mode marks on the selector switch knob) and the central piece which goes on the shaft. If the outer piece got dislodged, then it's very easy to put it back in the wrong position (180 degrees around). If it happened then the dial reading does not match the real setting. If this is the issue, assemble the knob in the right way and, using couple drops of a Crazy Glue, attach both pieces together. Gene.
__________________
Professional appliance repair in Los Angeles, California. |
| Display Modes | |
| Timer for GE double oven | carobe | Oven Repair (including Ranges and Cooktops) | 30 | 10-03-2008 12:38 PM |
| Whirlpool Double Wall Oven - Top Oven Not Working | bigguy | Oven Repair (including Ranges and Cooktops) | 6 | 09-18-2008 10:03 AM |
| Double Oven not working | pk4760 | Oven Repair (including Ranges and Cooktops) | 0 | 11-24-2007 11:53 AM |
| Double Oven--Main oven not working | bccavanaugh | Oven Repair (including Ranges and Cooktops) | 1 | 09-15-2007 11:22 PM |
| double oven won't bake | lou | Oven Repair (including Ranges and Cooktops) | 4 | 09-13-2007 06:50 AM |
