Right rear (simmer) burner on the range will no longer light. Can light it with match and all burner ports are clean. Ceramic on igniter is chipped. When that burner knob is set to light position appear to get sparking at all burners. Is igniter the problem? If so, can it be replaced without removing the range top?
