Discuss
Whirlpool Flat Top Stove...few burners not heating
 in
I've actually had this problem for over a year. Now it's getting worse since another burner stopped working. I have
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Whirlpool Flat Top Stove...few burners not heating
  #1 (permalink)
Old 09-08-2011, 06:45 PM
Junior Member
blahblehblah is on a distinguished road
Default Whirlpool Flat Top Stove...few burners not heating
Brand: Whirlpool   Age: 5 - 10 years
I've actually had this problem for over a year. Now it's getting worse since another burner stopped working. I have a flat top stove and 2 of the burners stopped working. One of my other Big burners...only the outer ring seems to be lighting up.
Model #: rf378lxmb
Is there any way to fix this? What could be causing it? I'm hoping for a quick cheap fix or else I'll end up buying a cheap flat top stove in the <$300 range.
It's getting really difficult to cook now. Oven works fine. And 1 burner works perfectly. The right 2 burners don't work. The bottom left burner (a big burner) appears to only have the wider outer ring working...
Any help appreciated!
  #2 (permalink)
Old 09-09-2011, 06:49 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
A model number may help others help you.
You will have to open it up and take a look.
Could be some wires have burned off.
Could be the infinite switches are failing.
Be sure to remove power from the unit when working on it.
__________________
  #3 (permalink)
Old 09-09-2011, 10:19 PM
Junior Member
Default
Oops, forgot the important part.
Model #: rf378lxmb
I don't know if it's worth it to just get a new range if I can find a good deal under $400. I took a quick look at some parts and it seems any replacement switch or burner will cost at least $50-100. Seeing how I have 3 that are malfunctioning... hmm.
Any suggestions for what could be the problem? Never opened a stove before...so I'd have to figure out how to do that and what I'm looking at as well. Could be fun
Thanks in advance!
  #4 (permalink)
Old 09-10-2011, 04:19 AM
Senior Expert
APP Volunteer
Default
If you decide to try fixing it the following should help.
De sure to unplug the unit when working on it.
The parts
Replacement parts for WHIRLPOOL RF378LXMB0 30" ELECTRIC CERAN FREESTANDING RANGE SELF CLEAN OVEN | AppliancePartsPros.com
See the attachment for the the tech sheet.
The service manual
http://appliancedigest.com/index.php...service-manual
You have to join the site to download the manual but it is free and this is a very good site for manuals and other info for the appliance repair DIYer.
A meter will let you check the elements to see if they are OK.
If the element and the wiring are OK then the infinite switch is the likely culprit.
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
stove burners not heating, nor oven or broiler. JMillion Oven Repair (including Ranges and Cooktops) 9 12-19-2017 07:26 PM
whirlpool stove getting power, but burners not getting hot lor911 Oven Repair (including Ranges and Cooktops) 4 11-14-2009 03:11 AM
Whirlpool flat cooktop stove (w/Schott Ceran top) neustkg General Talk 2 12-13-2008 05:38 AM
Whirlpool Oven & Stove Burners Will Not Ignite SergioC Oven Repair (including Ranges and Cooktops) 5 09-18-2008 07:26 PM
Kenmore flat top panel and oven quit, burners work Whaleman Oven Repair (including Ranges and Cooktops) 4 01-31-2008 05:34 PM
