Discuss
F2
 in
The digital read-out indicates F2. The fault codes indicate that this may mean the oven is too hot. In
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » F2
  #1 (permalink)
Old 11-29-2007, 06:00 PM
Magic Chef Magic Chef is offline
Junior Member
Magic Chef is on a distinguished road
Default F2
Model Number: 64HN-4TKVW   Brand: Magic Chef   Age: More than 10 years
The digital read-out indicates F2. The fault codes indicate that this may mean the oven is too hot. In this case, the oven was not even on at all. The stovetop burners were previously on, but the F2 came up about 15 minutes after the burners were shut off.
Oven and burners seem to work fine otherwise.
What to do?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 11-30-2007, 06:26 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
The first thing I would check is the oven sensor.
Unplug the sensor harness and check the resistance. It suppose to be about 1100 Ohms at the room temperature.
Replace the sensor if it's wrong reading.
Check wires from the sensor to the control board.
If there is nothing wrong, replace the control board (aka clock).
- The part number for the oven sensor AP2042837
To find out the right part number for the control board I need the complete serial number of the range.
- Here are the break down diagrams for the Magic Chef range Model 64HN-4TKVW
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 02-19-2008, 06:19 PM
molasses molasses is offline
Junior Member
molasses is on a distinguished road
Default f4, f2 error codes
thank you gene for your information. I called Magic Chef to get parts and to confirm what the error codes meant. They confirmed the possible problems, but would not elaborate, and could not sell me that parts. Not only does appliancepartspros have the parts, but they have advice. Thank you for being availabe.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
