| » heating element crackling and popping and turning brighter than the rest |
Model Number: J HC56 OV7AD Brand: GE Age: More than 10 years
Last night the wife was cooking and all of the sudden, there was some crackling and popping going on in the lower of the two ovens. (The upper one was not in use).
Looked in the oven and a small section, maybe an inch or so long was glowing much brighter and looked like there was something melting on it. Turned it off immediately and the noises stopped. Upon further inspection, it appears that the heating element (it's the lower element of the two), was melting? Is this a normal occurance in the wear and tear catagory? The oven was clean and there was nothing slipped on the element itself. I'm at geecue301@yahoo.com if someone can help me out that would be great. This is my first post. Ads By Google Related Models |
Here is a link I think your stove is included is the series
Model Search The "o" in your model number is a zero and also cannot have spaces when searching. Check the picture in the parts list just to be sure it is the same. Click on the picture and you will get a better view. Unplug the unit. Just undo the screw and gently pull it forward. Saw a post where the tech put a clothes pin on the wires to prevent them from going back into the oven. Great idea! If you have problems getting the wires off due to cramped space remove the back panel and do it from the back. You do not want to break the wires. If the wire ends are dirty clean them up with some very fine emery cloth before reattaching.
__________________
Here is the one that I think it is.
Just compare it to yours Part Details - GE Broil element, part number: AP2031008
__________________
Is this a closer match
Part Details - GE Element bake, part number: AP2031084
__________________
| Display Modes | |
| 6" Expandable element not turning on | Slash8789 | Oven Repair (including Ranges and Cooktops) | 2 | 01-03-2010 06:55 AM |
| Replaced heating element now heating element nor broil element work, all else does | rontetley | Oven Repair (including Ranges and Cooktops) | 1 | 10-26-2009 01:30 PM |
| bake element not heating but broil element heating okay | horno | Oven Repair (including Ranges and Cooktops) | 1 | 10-04-2009 11:37 AM |
| Dual Element Coil Keeps Turning On/Off | Waldo | Oven Repair (including Ranges and Cooktops) | 0 | 08-09-2009 08:21 AM |
| Dryer turning but not heating | lthompson | Dryer Repair | 6 | 02-19-2009 05:34 AM |
