Discuss
Timer for GE double oven
 in
My analog clock/timer died on my GE double built-in oven. I ordered the replacement part WB19X10006 and installed
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Timer for GE double oven
  #1 (permalink)
Old 11-28-2007, 07:11 PM
carobe carobe is offline
Junior Member
carobe is on a distinguished road
Default Timer for GE double oven
Model Number: JKP36GOH1BG   Brand: GE   Age: More than 10 years
My analog clock/timer died on my GE double built-in oven. I ordered the replacement part WB19X10006 and installed it. The only problem I have is that the bottom oven will no longer clean. The SET light comes on; the CLEANING light comes on. But TEMP light does not come on; LOCKED does not come on; and oven never starts heating. The top oven works as it should. Is there a setting on the new part that has not been addressed for a built-in double oven??? Can anyone help me get my appliance back in the A1 condition it was in before the clock went out?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 11-28-2007, 09:36 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Does this oven work in a timed cook mode?
If it does not, then possible a miswiring for the lower oven.
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 11-29-2007, 08:41 AM
Junior Member
Default
Gene, Thank you for your prompt reply.
The oven DOES work in timed mode.
  #4 (permalink)
Old 11-29-2007, 12:26 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Check the door latch and switches on the door latch.
__________________
  #5 (permalink)
Old 11-29-2007, 12:45 PM
Junior Member
Default
Latch and door checked and are fine. By the way, this oven worked fine in all modes including self-cleaning prior to installation of this part.
  #6 (permalink)
Old 11-29-2007, 03:24 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
In such situation possible you have the new clock defective.
You have to contact the place where you purchased from for a warranty replacement.
__________________
  #7 (permalink)
Old 11-30-2007, 06:56 PM
Junior Member
Default
Gene,
Thank you for all of your responses. I have requested a new part and if it works, that will tell us that the 1st one I received is defective and I will be mailing that one back
  #8 (permalink)
Old 11-30-2007, 07:02 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
when you will install the new one, be very careful with wires and follow the installation instructions step by step.
__________________
  #9 (permalink)
Old 02-01-2008, 11:54 AM
Sinayu Sinayu is offline
Junior Member
Sinayu is on a distinguished road
Default Timer replacement
Hi Carobe,
I am also trying to replace an old mechanical GE range timer/clock module. My old timer module is GE Model: 3AST51T170A1F. You mentioned that you bought a WB19X1006 as a replacement. Is this a Universal GE Digital Range Timer replacement for the old mechanical part?? Would appreciate a reply on this.
  #10 (permalink)
Old 02-01-2008, 02:39 PM
Junior Member
Default
The WB19X1006 Digital Electronic Timer replaced the following: WB19X0142, WB19X5269, WB19X5231, WB19X5282, and WB19X5223. Based on that, it seems that this part would NOT be the replacement for your part. My oven is GE Model JKP36. As you saw by the threads, we did receive another part to determine if the first one was defective. It did the same thing - everything works EXCEPT cleaning the bottom oven. I finally called GE repair and a repair technician came out and spent 2 days - and could not solve the problem. This oven is 22 years old; well, the technicians have never seen this model nor the inner workings of it!!! He did consult a retired expert, who gave him a few suggestions, but to no avail. I tell you this because you may run into the same problem as far as the age of the technicians are today and the changes made in the product. Good Luck
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool Double Wall Oven - Top Oven Not Working bigguy Oven Repair (including Ranges and Cooktops) 6 09-18-2008 10:03 AM
Double Oven not working pk4760 Oven Repair (including Ranges and Cooktops) 0 11-24-2007 11:53 AM
Kenmore double oven, Electric Freddyk Oven Repair (including Ranges and Cooktops) 1 11-21-2007 08:14 PM
Double Oven--Main oven not working bccavanaugh Oven Repair (including Ranges and Cooktops) 1 09-15-2007 11:22 PM
double oven won't bake lou Oven Repair (including Ranges and Cooktops) 4 09-13-2007 06:50 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
