How hard is it to install the bake element does it install from the front or from the back
MOST of the time you can do it from the front, Dis-connect the power,remove the 2 screws that hold it in place, GENTLY pull it toward you, remove the 2 wires,(put a close pin on the wires,so they don't go into the rear of the oven) and reverse to put it back together!!!:)
Originally Posted by: Drags1998 MOST of the time you can do it from the front, Dis-connect the power,remove the 2 screws that hold it in place, GENTLY pull it toward you, remove the 2 wires,(put a close pin on the wires,so they don't go into the rear of the oven) and reverse to put it back together!!!:) I let the plugs go back into the oven ... how do I get them out now?
