I need to partially remove the back of the cook top to replace the end caps (part # WPL 74004549 &74004548) on both side of the stove. There is one screw that needs to be removed that can only be accessed if the top has been raised.
THIS FORUM IS DEAD!!!!!!! |
Thank you very much. I have found the information that I needed:)
