The manufacturer has replaced part number WB21K39 with this item, part number WB21K10050.Now the burner valve switch doesn't fit.
Hello Lilsaint_. Per the manufacture, if using WB21K10050 to replace WB21K39, you must also replace the switch. Hope this helps. Part number: AP2632529
