| » GE oven stopped working |
Model Number: JBP90T0F2WW Brand: GE Age: 1 - 5 years
One day, I came home and found a strong typical "electrical burn" odor after a helper used the oven.
The control unit is not working except the clock, but it is impossible to reset the time. The 4 cooking units of the stove top work as usual. The warming zone activated by the control unit does not work. I replaced the control unit to no avail. I also replaced the oven self cleaning locking unit and that did not help either. I am running out of ideas. Is there a "hidden" fuse? Any other possibility? I would appreciate any help. Ads By Google Related Models |
Hello Levendel. Based on the information you provided, it sounds like the membrane is bad and will need to be replaced. Check and make sure the ribbon cable is clean and dry and is seated good in the control board. If so, and the functions do not select, you will need to replace the membrane. Hope this helps.
Part number: AP3191725 Control panel replacement parts for General Electric JBP90TF2WW Electric range | AppliancePartsPros.com
__________________
Thanks for allowing AppliancePartsPros.com to assist you, Jeff K. / APP TEAM Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
| Display Modes | |
| GE Oven Stopped Working | spc1102 | Oven Repair (including Ranges and Cooktops) | 4 | 07-05-2011 11:25 AM |
| refrigerator stopped working cleaned it and started working then stopped working agai | ravaginggoatman | Refrigerator & Freezer Repair | 5 | 12-18-2010 01:13 AM |
| GE gas oven stopped working | redcon | Oven Repair (including Ranges and Cooktops) | 0 | 03-06-2010 11:45 AM |
| oven stopped working | dbc48 | Oven Repair (including Ranges and Cooktops) | 0 | 09-30-2009 10:16 AM |
| Oven Stopped Working | wolfpackpride | Oven Repair (including Ranges and Cooktops) | 1 | 10-03-2008 01:30 PM |
