Any help will be appreciated: My oven stopped working. Initially I thought it was the igniter so I replaced it. The oven still would not light so I called a local repairman and after running some tests he told me the igniter was good but safety valve was defective. I just replaced the safety valve and the oven still does not work. The clock is set, the gas supply line is on, the top burners light. What else should I look for?
Originally Posted by: LCB3 Any help will be appreciated: My oven stopped working. Initially I thought it was the igniter so I replaced it. The oven still would not light so I called a local repairman and after running some tests he told me the igniter was good but safety valve was defective. I just replaced the safety valve and the oven still does not work. The clock is set, the gas supply line is on, the top burners light. What else should I look for? It works! I don't know why but all of a sudden the oven is working now. I guess joining this forum was all I needed. This place rocks!
