Discuss
Thermostat or Switch?
 in
I have double oven that does not turn off with the thermostat. Turn the switch to the oven on position
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Thermostat or Switch?
  #1 (permalink)
Old 04-06-2009, 10:49 AM
chuckhaig chuckhaig is offline
Junior Member
chuckhaig is on a distinguished road
Default Thermostat or Switch?
Model Number: HBL 655   Brand: Bosch   Age: 1 - 5 years
I have double oven that does not turn off with the thermostat. Turn the switch to the oven on position and the upper oven turns on, but will not cycle off to maintain heat. I am down to the thermostat or switch. I don't want to replace the wrong part.
Related Models
Bosch HBL432 AUC (FD 8202-)
Bosch HBL435 AUC (FD 8202-)
Bosch HBL436 AUC (FD 8202-)
Bosch HBL442 AUC (FD 8202-)
Bosch HBL445 AUC (FD 8202-)
Bosch HBL446 AUC (FD 8202-)
Bosch HBL452 AUC (FD 8202-)
Bosch HBL455 AUC (FD 8202-)
Bosch HBL456 AUC (FD 8202-)
Bosch HBL532
Bosch HBL535
Bosch HBL536
Bosch HBL542
Bosch HBL545
Bosch HBL546
Bosch HBL552
Bosch HBL555
Bosch HBL556
Bosch HBL562
Bosch HBL565
Bosch HBL566
Bosch HBL632
Bosch HBL635
Bosch HBL636
Bosch HBL642
Bosch HBL645
Bosch HBL646
Bosch HBL652
Bosch HBL655
Bosch HBL656
Bosch HBL662
Bosch HBL665
Bosch HBL666
Bosch HBL742 AUC (FD 8207-)
Bosch HBL745 AUC (FD 8207-)
Bosch HBL746 AUC (FD 8207-)
Bosch HBL752 AUC (FD 8207-)
Bosch HBL755 AUC (FD 8207-)
Bosch HBL756 AUC (FD 8207-)
Bosch HBL765 AUC (FD 8207-)
Bosch HBN442 AUC
Bosch HBN445 AUC
Bosch HBN446 AUC
Bosch HBN452 AUC
Bosch HBN455 AUC
Bosch HBN456 AUC
Bosch HBN642
Bosch HBN645
Bosch HBN646
Bosch HBN652
Bosch HBN655
Bosch HBN656
Bosch HBN662
Bosch HBN665
Bosch HBN666
Bosch HBN742 AUC (FD 8207-)
Bosch HBN745 AUC (FD 8207-)
Bosch HBN746 AUC (FD 8207-)
Bosch HBN752 AUC (FD 8207-)
Bosch HBN755 AUC (FD 8207-)
Bosch HBN756 AUC (FD 8207-)
Bosch HBN765 AUC (FD 8207-)
Magic Chef HC309B-2 Hood
Magic Chef HC30AB-2 Hood
Frigidaire HC30C Frg(v1) / Range Vent Hood
Frigidaire HC30CL Frg(v2) / Range Vent Hood
Frigidaire HC8830S Frigidaire / Range Hood
Frigidaire HC8830W Frigidaire / Range Hood
Frigidaire HC8836S Frigidaire / Range Hood
Frigidaire HC8836W Frigidaire / Range Hood
Hardwick HCF120 Freezer - Vertical
Hardwick HCF170 Freezer - Vertical
Hardwick HCF200 Freezer - Vertical
Hardwick HCF200A Freezer - Vertical
Hardwick HCF200H Freezer - Vertical
General Electric HCK23LCMAFCC Refrigerator
Amana HCL305 Range - S/c S/i Ddraft Gas
Amana HCL605 Range - S/c S/i Ddraft Gas
Amana HCR305 Range - S/c S/i Ddraft Gas
Amana HCR306 Range - S/c S/i Ddraft Gas
Amana HCR3061L Hood
Amana HCR3061L Hood
Amana HCR3061W Hood
Amana HCR3061W Hood
Amana HCR307E Hood
Thermador HCSW36TB
Thermador HCSW36TS
Thermador HCSW36TW
Thermador HCSW42TB
Thermador HCSW42TS
Thermador HCSW42TW
Thermador HCSW48TB
Thermador HCSW48TS
Thermador HCSW48TW
Amana HCU-514 Range - S/c S/i Ddraft Gas
Amana HCU-514C Range - S/c S/i Ddraft Gas
Amana HCU-514D Range - S/c S/i Ddraft Gas
Amana HCU-514E Range - S/c S/i Ddraft Gas
Amana HCU-516 Range - S/c S/i Ddraft Gas
Amana HCU-516A Range - S/c S/i Ddraft Gas
Amana HCU-516C Range - S/c S/i Ddraft Gas
Amana HCU-516D Range - S/c S/i Ddraft Gas
Amana HCU-516F Range - S/c S/i Ddraft Gas
Amana HD-332 Mwave - Mounted Over Range/wo
Amana HD-336 Mwave - Mounted Over Range/wo
Amana HD-342 Mwave - Mounted Over Range/wo
Whirlpool HD100
Whirlpool HD1000JSC4 Hot Water Dispenser
Whirlpool HD1000JSN4 Hot Water Dispenser
Whirlpool HD1000JSW0
  #2 (permalink)
Old 04-07-2009, 03:26 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Default
Check the oven thermostat for continuity in "off" position. If the circuit is closed then the thermostat is bad. The wiring diagram will help you to find the correct thermostat terminals for diagnosis.
Here are the break down diagrams and Replacement parts for BOSCH HBL662 | AppliancePartsPros.com
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
cycle switch or motor switch fails andygregg Washer Repair 2 01-28-2009 11:25 AM
bought new thermostat and heater thermostat and now won't heat at all mgilbert6 Dryer Repair 0 09-07-2008 10:58 AM
Oven Thermostat switch goes on and off by itself Judy B Oven Repair (including Ranges and Cooktops) 1 03-27-2008 07:45 PM
Relay switch wont engage automaticaly to turn ac on per thermostat lolo Heating, Ventilation, and Air Conditioning (HVAC) 3 01-16-2008 06:56 PM
infinite switch wiring change from 6 wires to 5 wire switch wiedemanndds Oven Repair (including Ranges and Cooktops) 3 12-06-2007 01:45 PM
