Discuss
Problem Connecting Ribbon Cable to Control Board
 in
Thanks to Gene on this board I think I correctly identified a bad control board on my double whirlpool oven.
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Problem Connecting Ribbon Cable to Control Board
  #1 (permalink)
Old 08-29-2011, 10:11 AM
Junior Member
Horizons59 is on a distinguished road
Default Problem Connecting Ribbon Cable to Control Board
Model Number: GBD307PDQ5   Brand: Whirlpool   Age: 5 - 10 years
Thanks to Gene on this board I think I correctly identified a bad control board on my double whirlpool oven. I removed the old one and most of the connectors are simple. However, the ribbon cable from the keypad is delicate and has no connector. The connector receptacle on the control board has a tab on each side. I'm assuming these tabs open the pin connectors inside the connector body to allow the ribbon cable to be easily inserted and then tighten when the tabs are released.
However, whether I press down or press the tabs together towards the connector body, I see no movement in the connect pin connections inside the connector.
I am afraid to force the ribbon cable in as I might damage the frail ribbon cable and then I would need to buy the keypad replacement.
Any ideas on how to properly insert the ribbon cable from the keypad into the control board? Thanks
Ads By Google
Related Models
Whirlpool GBD307PDQ5
Whirlpool GBD307PDQ6
Whirlpool GBD307PDQ7
Whirlpool GBD307PDS09 30" Built - in Electric Double Oven Convection - Upper Self - Clean (gold Line)
Whirlpool GBD307PDS1
Whirlpool GBD307PDS10 30" Built - in Electric Double Oven Convection - Upper Self - Clean (gold Line)
Whirlpool GBD307PDS2
Whirlpool GBD307PDS3
Whirlpool GBD307PDS4
Whirlpool GBD307PDS5
Whirlpool GBD307PDS6
Whirlpool GBD307PDS7
Whirlpool GBD307PDT09 30" Built - in Electric Double Oven Convection - Upper Self - Clean (gold Line)
Whirlpool GBD307PDT10 30" Built - in Electric Double Oven Convection - Upper Self - Clean (gold Line)
Whirlpool GBD307PDT3
Whirlpool GBD307PDT4
Whirlpool GBD307PDT5
Whirlpool GBD307PDT6
Whirlpool GBD307PDT7
Whirlpool GBD307PRB00 30" Built - in Electric Double Oven Convection - Upper Self - Clean (gold Line)
Whirlpool GBD307PRB01 30" Built - in Electric Double Oven Convection - Upper Self - Clean (gold Line)
Whirlpool GBD307PRQ00 30" Built - in Electric Double Oven Convection - Upper Self - Clean (gold Line)
Whirlpool GBD307PRQ01 30" Built - in Electric Double Oven Convection - Upper Self - Clean (gold Line)
Whirlpool GBD307PRS00 30" Built - in Electric Double Oven Convection - Upper Self - Clean (gold Line)
Whirlpool GBD307PRS01 30" Built - in Electric Double Oven Convection - Upper Self - Clean (gold Line)
Whirlpool GBD307PRS02 30" Built - in Electric Double Oven Convection - Upper Self - Clean (gold Line)
Whirlpool GBD307PRT00 30" Built - in Electric Double Oven Convection - Upper Self - Clean (gold Line)
Whirlpool GBD307PRY01 30" Built - in Electric Double Oven Convection - Upper Self - Clean (gold Line)
Amana GBE22AA Range - Electric Std Delaware
Amana GBE22AA0CEM Range - Electric Std Delaware
Amana GBE22AA0CP Range - Electric Std Delaware
Amana GBE22AA0PT Range - Electric Std Delaware
Amana GBE22AA5CEM Range - Electric Std Delaware
Amana GBE22AA5PT Range - Electric Std Delaware
Amana GBE22AAOCP Range - S/c S/i Ddraft Gas
Amana GBE22AAOEPT Range - S/c S/i Ddraft Gas
Amana GBE22AAOPT Range - S/c S/i Ddraft Gas
Amana GBE22GP Range - S/c S/i Ddraft Gas
Amana GBE24AA Range - Electric Std Delaware
Amana GBE24AA0CT Range - S/c S/i Ddraft Gas
Amana GBE24AA0EPT Range - Electric Std Delaware
Amana GBE24AA0PT Range - Electric Std Delaware
Amana GBE24AAOCP Range - S/c S/i Ddraft Gas
Amana GBE24AAOPT Range - S/c S/i Ddraft Gas
Amana GBE24CB Range - Electric Std Delaware
Amana GBE24CC Range - S/c S/i Ddraft Gas
Amana GBE24FC Range - Electric Std Delaware
Amana GBE26AA Range - Electric Std Delaware
Amana GBE26AA0CP Range - Electric Std Delaware
Amana GBE26AAOCP Range - S/c S/i Ddraft Gas
Amana GBE26AB Range - Electric Std Delaware
Amana GBE26CB Range - Electric Std Delaware
Amana GBE26CK Range - S/c S/i Ddraft Gas
Amana GBE26DA Range - Electric Std Delaware
Amana GBE26DB Range - Electric Std Delaware
Amana GBE26DC Range - Electric Std Delaware
Amana GBE26EB Range - Electric Std Delaware
Amana GBE26FB Range - Electric Std Delaware
Amana GBE26FC Range - Electric Std Delaware
Amana GBE26FCOD Range - S/c S/i Ddraft Gas
Amana GBE26GC Range - Electric Std Delaware
Amana GBE56FB Range - Electric Std Delaware
Frigidaire GBF117EL Frg(v2) / Gas Range
Frigidaire GBF117EW Frg(v1) / Gas Range
Amana GBK22AA Range - S/i Std Gas
Amana GBK22AA092M Range - S/i Std Gas
Amana GBK22AA0PU Range - S/i Std Gas
Amana GBK24AA Range - S/i Std Gas
Amana GBK24AA092M Range - S/i Std Gas
Amana GBK24AA0PU Range - S/i Std Gas
Amana GBK24CB Range - S/i Std Gas
Amana GBK24CC Range - S/c S/i Ddraft Gas
Amana GBK24FC Range - S/i Std Gas
Amana GBK26AA Range - S/i Std Gas
Amana GBK26AA092M Range - S/i Std Gas
Amana GBK26AA0PU Range - S/i Std Gas
Amana GBK26AB Range - S/i Std Gas
Amana GBK26CB Range - S/i Std Gas
Amana GBK26DB Range - S/i Std Gas
Amana GBK26DC Range - S/i Std Gas
Amana GBK26EB Range - S/i Std Gas
Amana GBK26FB Range - S/i Std Gas
Amana GBK26FC Range - S/i Std Gas
Amana GBK26FS0 Range - S/i Std Gas
Amana GBK26FS5 Range - S/i Std Gas
Amana GBK26GC Range - S/i Std Gas
Amana GBK26HC Range - S/i Std Gas
Amana GBK28DC Range - S/i Std Gas
Amana GBK28FG Range - S/i Std Gas
Amana GBK28HG Range - S/i Std Gas
Amana GBK29AA Range - S/i Std Gas
Amana GBK29AA092M Range - S/i Std Gas
Amana GBK29AA0PU Range - S/i Std Gas
Amana GBK39AA Range - S/i Std Gas
Amana GBK39AA/ALL Range - S/c S/i Ddraft Gas
Amana GBK39FA Range - S/i Std Gas
Amana GBK39FA/ALL Range - S/c S/i Ddraft Gas
Amana GBK39HG Range - S/i Std Gas
Amana GBK39HG/ALL Range - S/c S/i Ddraft Gas
Amana GBK56FB Range - S/i Std Gas
Amana GBL39AA Range - S/i Std Gas
Amana GBL39AA/ALL Range - S/c S/i Ddraft Gas
Amana GBL39FA Range - S/i Std Gas
Amana GBL39FA/ALL Range - S/c S/i Ddraft Gas
Amana GBL39HG Range - S/c S/i Ddraft Gas
Amana GBL39HG/ALL Range - S/c S/i Ddraft Gas
  #2 (permalink)
Old 08-29-2011, 03:10 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
The little black frame on top of the connector should come up to release the ribbon cable. It should be in the upper position while you inset the ribbon cable into the connector. The ribbon cable has to go all the way into the connector to provide full and reliable connection. After you finish it, the locking frame should be pushed in.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 08-31-2011, 01:40 PM
Junior Member
Default
Thanks Gene. Got the control board and the ribbon cable in, powered up the oven and the error codes are gone. However, not all of the buttons are responding so I am thinking that there might be some settings required when you plug in a brand new control board. Is there a service manual or somewhere you can point me to get the control board configured properly? Thanks in advance.
  #4 (permalink)
Old 08-31-2011, 04:24 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
The Tech sheet says that you have to program the cavity size after you replaced the control board.
Do the following:
1. Within 60 seconds of power up, press the following touch pads:
LOWER OFF, UPPER OVEN, BAKE, TEMP DOWN, TIMER OFF, MINUTE DOWN, START, CLOCK, LIGHT.
2. Size is shown in display - “ID 24”.
3. Press CLOCK pad until correct size is displayed.
4. Press CANCEL.
5. Press and hold LOWER OFF pad for 5 seconds to verify programming.
There are no other instructions for the control board programming.
__________________
  #5 (permalink)
Old 09-13-2011, 10:44 AM
Junior Member
Default
Thanks Gene but I think I need a service call as I am still seeing problems with the panel and display. I live in Ladera Ranch (south OC). What number do I call for your service? Thanks
  #6 (permalink)
Old 10-11-2011, 06:16 AM
Junior Member
brillj is on a distinguished road
Default Ribbon connection different on new control board
Whirlpool Double Oven Wall unit black model no. GBD307PDS10. Oven would beep and LED screen would go blank. Came back on in a couple of days and went out again. Ordered control board from Whirlpool's supplier ************** part # W10406070. Everything connected except for ribbon connector. Connector is different and reading the forum looks like the ribbon cable may be different. Whirlpool and the supplier are no help.
What do I need to fix the oven...?
John
  #7 (permalink)
Old 10-11-2011, 03:26 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
John,
Can you post a pictures of the old and new ribbons?
__________________
  #8 (permalink)
Old 10-12-2011, 03:59 PM
Junior Member
Default
Hi Gene,
Thanks for the quick reply. It's not the ribbon cable that is different. It's the ribbon cable connector on the new control board that is different. The ribbon cable comes from the key pad assembly. That's what I'm not sure if I need to order now that the connector is different on the control board.
Hopefully these pictures will help.
  #9 (permalink)
Old 10-12-2011, 09:06 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Did you try to plug the ribbon cable into the new board connector? I believe it should fit.
This control board is direct replacement made by Whirlpool and there are no any additional installation instructions for this part.
__________________
  #10 (permalink)
Old 10-13-2011, 07:49 AM
Junior Member
Default Connecting Ribbon Cable to Control Board
Hi Gene,
Yes, I did try to plug in the ribbon cable to the new control board. It never seated and popped right out. Also, and I know it's hard to tell by the pictures, but the ribbon cable connector on the new board is different.
The 1st picture is the ribbon connector for the old control board, the 2nd picture is the top part of the original ribbon cable connector and the 3rd the new board. The top of the ribbon connector had two tabs at each end that would seat and snap in place. The connector on the new board does not have that and the new board did not come with that piece.
I don't know if it is a matter of finding the correct top part of the ribbon connector that would work with the new board. Or will I have to get a new control panel assembly w/membrane switch (key pad).
Thanks,
John
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Oven control panel ribbon cable at p5 simonerocks Oven Repair (including Ranges and Cooktops) 0 07-15-2011 03:44 PM
New Control Panel has a different ribbon cable kvalentine Microwave Repair 3 07-30-2010 03:45 PM
Detaching GE Oven Ribbon Cable jdsmith77 Oven Repair (including Ranges and Cooktops) 2 03-17-2010 02:13 PM
Jenn-Air ribbon cable sfjinarl Oven Repair (including Ranges and Cooktops) 0 09-30-2009 03:08 PM
problem connecting display power ribbon Jimnjo Oven Repair (including Ranges and Cooktops) 2 02-28-2009 05:30 AM
